I'm assuming what you're calling the boost button is a Winegard Wall Plate amp like the one in the front in this pic:
(Note that the amp is really in the antenna; the plate just turns it's power on and off.)
There should be coax from the wing antenna on the roof to the back of this plate. There is also a coax from your outside satellite input (if you have one) to the back of the plate. There is also a coax from your outside cable input to the back of the plate.
You connect another coax from the front of the plate to your TV.
I've attached instructions for the plate below.
2011 Traverse LT, 3.6L, FWD
