Old 08-30-2018, 08:47 PM   #21
Originally Posted by udflyer View Post
what do you use for lube?
Doesn't require anything special. Wheel bearing grease is what I use because I always have some around. Big thing is to cover the hitch when not hooked up.
A split tennis ball at the least over the ball itself to keep dirt from covering it while you drive around unhitched. Even better, cover the whole hitch assembly with a plastic bag, even if it's removed and stored.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
Old 08-30-2018, 11:18 PM   #22
Thanks very much for the advice everybody. It worked like a charm!
Troutd0g is offline   Reply With Quote
