If you use tape to repair a tear or hole it's a good idea to radius the corners with a pair of scissors before applying. Sharp corners tend to lift while radius'd corners will stay flat.
Even if repairing a tear at the edge and wrapping the tape over it, make sure that the corners are rounded for a neater, longer lasting, repair.
