Old 03-28-2017, 07:46 PM   #1
heater byass location 2017 Rockwood Roo
Trying to find out where the water heater bypass valve is located in a 2017 Rockwood Roo 233s. I didnt see any kind of access behind the water heater itself. Thanks in advance for your help.
Brian A is offline   Reply With Quote
Old 03-28-2017, 09:26 PM   #2
Look around for the hot water tank, which will be covered in styrofoam. You should find three 1/4 turn valves, you will need to turn all 3. I have a 2013 233S and my hot water tank is under the sofa towards the front of the camper. If you are dewinterizing your camper, make sure you have run water through all of your lines to get rid of the RV antifreeze before you turn any of the bypass valves
theengle is offline   Reply With Quote
Old 03-28-2017, 09:36 PM   #3
Looking at2017 233s pics online, looks like your WH should be under the sofa like theengle's.
2011 Traverse LT, 3.6L, FWD
Old 03-30-2017, 02:43 PM   #4
Take The Road Less Travld
MuddauberE's Avatar
View the images in this forest river forum. It should help you see where they are.
http://www.forestriverforums.com/for...33s-36866.html
"Take The Road Less Traveled"
2020 Cherokee 294BH
2021 Chevy Silverado 2500HD 6.6 Duramax Diesel
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
MuddauberE is offline   Reply With Quote
cat, heater, location, rockwood, rockwood roo, roo
