This past spring I purchased a used 21DK and was a little concerned about towing it with my 2007 Honda Ridgeline. I was on the boarder of my towing capacity since the 21DK was 4010 dry with a 590 pound tongue weight and the Honda has a towing capacity of 5000 pounds with 600 pounds of tongue.
Well, I've towed it probably 700 miles now and I have to say, I'm very pleased with how it tows...Yes I do take my time, nothing more the 60/65 and the truck will downshift when I go up grades but it's not screaming or obnoxious and I'm getting around 11 miles per gallon. I have had to make some quick stops and maneuvers and it behaved surprising very well too.
A few things I did/do.
- The factory hitch was rated for 500 pounds of tongue so I upgraded to a 700 pound hitch.
- I'm also using a equalizer weight distribution hitch, even though Honda does not recommend using one.... It's a game changer since it lessens the rear end squat which keeps the truck level and no sway at all unless I get passed by a big semi truck.
- I also inflate the tires on the truck to 40 pounds
- Since I have the RTX version of the Ridgeline it came standard with a transmission cooler or that is something I would have added.
- I also added an electric break controller.
Having said all this, I'm still lusting after a Chevy Silverado High Country and I'm sure it would tow it better... But for now I'm satisfied the Honda meets my needs and I'm not out $50K for a new truck
