How do you get the drawers to release from the slides too was in for service they reattached the dinette but did not put the drawer I right just sitting in there only held in with 1 screw I can't get the drawer out to fix myself help!!!
When you fully extend the drawer look at the slide on side of drawer about mid way there will be a black or brown plastic lever, push these both down and pull the drawer out then.
dado39 Sorry can't help you on this one never seen slide like that, all ones I have worked on had a slide release lever or tab to pull out to remove drawer.
Looks simple. The cut out on the slide is there for a reason and i think it stops the drawer from coming all the way out. Slide the drawer all the to the stop. Put a screwdriver in between the drawer hardware and the slide and move the slide outwards away from drawer. The notch should then clear. You will have to do one side at a time.
Good luck
Mike
Got it there were little black levers could not see in the camper so I took the drawer out only 1 screw holding it in they striped all but 1 . I used pop rivets to hold it to the aluminum frame and larger screws in the wood. One of the drawer slides is screwed up will have to have new ones ordered when I put those in I will bolt through the aluminum tubing for more secure fit
