Originally Posted by rockfordroo
Just tell us how many threads are necessary before it's no longer hearsay.
Can you tell me how many of those threads related to a filter that "just broke" or they failed because they were over-tightened, froze the last winter because someone forgot to empty, etc?
Something that also seems to be overlooked is that the filter in question has been re-designed and the original "ratchet type" is no longer being installed. My 2018 came with an entirely different base and canister but still uses the KW-1 cartridge.
New style:
Old style Canister:
FWIW, it's hearsay unless someone is telling the story first person.
Biggest issue that I glean from "FW-1 Threads" is that the housings are mounted in hard to access areas (no issue there) and the filter cartridge is more expensive than a cheap inline Camco filter from Walmart. (you get what you pay for).
I just take issue with posts made by people
who haven't had the problem but will go to great lengths to tell the world that the FR-1 Filter is going to break or leak, again repeating what they read or heard.
FWIW, lost in the noise are the posts by those who say they've never had a problem with theirs. A common industry statistic, only one in ten people will actually leave a good review on a product they use so it would logically extend that 90 percent of those who are not having these filters magically break or leak all on their own are remaining silent.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
