Those can be a bugger to track down. I had a very similar leak with my micro lite although mine was under the shower basin and not the sink. It turned out to be a partial hairline fracture in the black drain pipe. Yours may not be the same problem but if it is here's what I did...
I dried all the plumbing under the sink really well (even used a hair dryer on the drain pipe). Next, I had someone open one faucet at time while you run your hands along the piping to see where the leak starts from. Its important to catch it as it starts before the water begins to travel along a surface. Keep opening different faucets if there are multiple drain pipes in the area.
Once I found the hairline crack I simply applied Eternabond tape to fix. Drain pipe leaks are not under pressure and Eternabond tape works well for those repairs.
Good luck
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
