10-29-2016, 07:24 PM
low point drain '17 21ss
so I see the sticker that says low point drain but after crawling under the camper I don't see them anywhere, any pics or directions to them?
'17 Flagstaff Shamrock 21ss
'13 Grand Cherokee-5.7
10-29-2016, 07:31 PM
Go inside your unit to the area where the sticker is.
Look inside of what ever is there, you may need to remove a false panel to get to the valves.
10-29-2016, 11:58 PM
Roo's don't have valves, just caps.
2011 Traverse LT, 3.6L, FWD
10-30-2016, 12:54 AM
Older Roos DO have low point valves, not caps.
My 2007 23SS has the H/C valves for the low point drains under the sofa.
10-30-2016, 08:42 AM
OK. My 2012 only had caps. The OPs is a 2017.
10-30-2016, 09:05 AM
I have a 2016 21ss, mine are right behind the sticker about an inch off the skirting and 2 inches through the floor. Hard to locate at first. Going to extend and add valves before spring.
10-30-2016, 10:47 AM
you were correct, thank you sir, was way up there. ill be adding a extension and valve next year
10-30-2016, 01:04 PM
Boondocking Only
Mine has caps, both white. The PVC pipes are 1 red & 1 blue. I needed a flashlight to find them the 1st time I crawled underneath. They come down about 4 inches & are kinda tucked up close to the frame, so they are hard to see. Once you find them it's very easy the next time.
2014 Shamrock/Roo 21SSL
Complete LED Lighting
Off Road Package
2010 F250 Lariat 6.8 V-10 w/Timbren SES
Custom Tunes by 5 Star Tuning
Boondocking Only
11-08-2016, 01:14 AM
Any idea on what size valve/thread to they use? I'd also like to at least at the valve as those caps seems like they are going to be way to easy to lose.
- 2022 Rockwood Roo 235s
- 2002 Avalanche 2500 8.1L 4x4
- 2017 Rockwood Roo 21DK (SOLD)
- 2001 Coleman Utah (SOLD)
11-08-2016, 06:34 AM
Some have a Special washer that is easy to lose also ! Youroo! !
11-09-2016, 09:39 PM
I put 1/4 turn valves on mine a couple years ago when one of my caps were leaking. Just take your cap with you to figure out what size/thread you need.
'18 Ford F250 Lariat Super Crew
'22 Rockwood 2608BS
Previous '17 Grand Design Imagine 2800BH, '13 Rockwood Roo 21SS
11-10-2016, 04:40 PM
Perversely,
My '16 21ss has black caps against the black floor, with just enough white threads sticking through to get them on. Found them by touch.
2023 Coachman Apex UL 243FKS, 2016 F150
