Originally Posted by sunnyside1
I am thinking this shouldn't be that hard a DIY project. However the notion of drilling holes in a unit I haven't even camped in yet makes me nervous. Any feed back?
This certainly can be a DIY job. I had all the stuff to mount my two 100 watt panels on the roof, but after using them with as a portable setup, I ended up staying with that. We just camp in too many places where trees would keep roof mounted panels out of the sun.
There isn't much solid structure in the roof of a hybrid. Its basically just two 1/4" sheets of plywood laminated together with a Styrofoam core. Look around the edge of your skylight from the roof to see the cross-section. Still capable of holding the panel though. The dealer bought from has done a bunch of these installs without issue.
I was going to use well nuts for the anchors, as they should give better holding power than just using screws. You could also try contacting FR to see if you can get a diagram showing the truss spacing to find solid anchor points. There are bracket kits out there that will leave you some space under the panel for air flow, and just seal up all the fasteners really well with dicor. The other key is to avoid shadows from the AC or other roof top objects. From there, you just need to find a route for your wiring down to the controller.
There are some good blogs around if you do a little searching with details about installing roof top systems.
2022 Columbus 379MBC (Previous 2013 Rockwood Roo 23 IKSS)
2023 F-350 (Previous 2017 F250, 2005 F-150)
