09-14-2022, 09:21 PM
New latch design
In my never ending quest to solve my bunk door seals leaking when closed I found tonight they have a new style door latch system that incorporates a cover over the top of the door.
For those of us that are plagued with the inferior design up to early 2022 I thought I would share this information.
I am attaching a pic of the new design and will be calling FR soon for more details.
I have a 2019 23ikss FWIW.
09-15-2022, 12:02 PM
interesting - it looks as though the 'clamp' is now the entire length of the top edge, and includes a sort of rain gutter, as opposed to 'ears' attached to either corner for earlier design
def would like to see this closer/better to see if there's something to be gleaned/added to our older style camper.
Thanks for the heads up, very interesting to see additions as the models mature.
2022 Rockwood Roo 235S
15kBTU AC; 12v fridge; 1kW roof-mounted solar panels; 80 amp MPPT charge controller; 3,500w pure sine wave inverter; 30a automatic transfer switch; MicroAir EasyStart, 600ah Chins LiFePo; Honda EU2200i (with Hutch Mountain propane conversion kit) gathering dust in the storage unit.
09-20-2022, 09:40 AM
Retired Panpsychist
Regarding your leaking issue, have you tried adjusting the tension of your closing mechanism? If not, I can dig around for the link to online instructions.
I tested my bunks by closing them with a dollar bill in the seal. I found one side of the front bunk allowed a little too much movement of the bill.
Theo & Carol
2007 GoldenDoodle ("Cooper") R.I.P.
2020 Rockwood Roo 23IKSS
2015 F-150 4WD XLT SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A), 1,980lb Payload
09-20-2022, 08:30 PM
Unfortunately I did and it did not work. I don’t think my door is warped at least by my eye but you never know.
09-21-2022, 12:50 AM
If your bunk latches are adjusted correctly they should not leak... use the dollar bill method,,, the bill should be just gripped slightly without flattening out the rubber seals. Plus I clean the seals with a 303 vinyl/rubber cleaner preservative once a year to preserve the seal.
I always leave all my zippers inside closed and the occasional cup of water that might leak in a downpour does no harm when I open the bunk... and only the front bunk has ever leaked.
I used to use 2 inch blue painters tape taped over the gap from top edge to bunk door to seal out rain over the winter but I have not needed to do that in the past 3-4 years.
2014 Shamrock 183
09-26-2022, 12:15 PM
I understand that in a perfect world with cleaning and the proper tension on the roto vise latch it shouldn’t leak but I swung by a local dealer and saw this in person on all the new units in stock and it looks like a much better system.
I snapped a better side pic of it.
09-26-2022, 01:14 PM
I pro-actively attached a piece of beige J channel from HD to sit just above the top of the beds when closed. I ran a bead of caulk both before and after I attached it. We have not had the issue. The new seal looks impressive in the photos although the J channel had to be cheaper .......
2023 Coachman Apex UL 243FKS, 2016 F150
09-26-2022, 02:52 PM
How far does that J channel over hang the top of the door and also what did you attach it with ?
10-05-2022, 02:04 PM
I am JEALOUS now!!
.... that new system appears to be ROCK ON!!!!
Just as RSdata shared, adjustments SHOULD solve most problems but I know I still have water leaks from time to time no matter how careful I am and I HAVE all adjustments the best they can be......
On our rig I THINK (this is just me, I haven't water hosed/witnessed to see or not) that MAYBE... the "cuts" the factory put in the 90 degree bends on our bunk weather seal at the top corners are the problem spot, I think that is where water leaches past when its raining cats and dogs.
THIS NEW SYSTEM strikes me as the perfect way to solve that issue!
Ed & Chris, Empty Nesters (missing Josh & Jaclyn)
along with Blue & Tessa, Cat Explorers!
2020 Rockwood Roo 235s
2019 F-250 Diesel 4x4 Super Duty
10-05-2022, 02:08 PM
P.S.
I did what UnderTheDog shared as well... I bought vinyl "J channel" from Lowes/Home Depot cut a notch in one side to allow a bend and I put it over the gap area between the rain gutter and the outside of the bed metal flange.... The triangle cuts in the top left/right corners allows me to keep the top edge of the channel solid and bents over to come down the side until they reach the clamp brackets.... I can take pictures later this week if someone wants to see BUT....
For me I leave this in place on our rear bunk because we don't open it often, I can only leave it on the front one when parked because the driving wing would ceremoniously remove it for me if I tried to leave it on
10-05-2022, 09:04 PM
Yes pics would be great !
10-06-2022, 12:05 PM
Just a "patch" I created... not the best but appears to work for now ;-)
Here goes!
First, it is "J channel" in the vinyl siding/eves/vent section at a HD/Lowes...
It looks like this from the end;
I cut small triangles front and back to allow a fold like so;
Then I stuck short edge in the rain gutter so long edge would be over outside.. this involved a slight "stretch" to open the channel enough to span the gap between the two;
You bend for the corners like so;
I made mine end at the top of each of the closure clamp mounts like this;
And when entire piece is in place it looks like so;
As I shared, I have left the back one on since installed but don't leave the front one on while I am driving. The back one has a few thousand miles of highway driving without being lost AND it survived the winds from IAN in Central Florida this past week.
Best of Luck!
10-06-2022, 01:23 PM
Thanks for the detailed pics!
This is probably what I will end up doing at least for winter storage anyway.
Do you find that it keeps most or all of the water out ?
10-06-2022, 04:27 PM
So far it has completely ended our small accumulations of rainwater we used to get in the vinyl canvas fold when the beds were stored
10-06-2022, 06:46 PM
Good to hear.
Thank you.
