Old 06-15-2024, 06:19 PM   #1
Superstroker1's Avatar
Please Help with cycling water pump
My 2015 23ss water pump turns on and off like itís priming the system every 5 minutes or so but I canít find a leak anywhere any help would be greatly appreciated thanks
Superstroker1 is offline   Reply With Quote
Old 06-15-2024, 06:32 PM   #2
Chuck_S's Avatar
It's probably keeping the system pressurized. Any check valve leakage allowing water back toward the tank will drop the pressure and the system wants to put it back. There should be a pump rebuild kit, find the model number of your pump and order. Or replace the pump or the head. The rubber valves may fix it and I see them as a kit for less than $20.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 06-15-2024, 06:38 PM   #3
The first time mine cycled, I found a leak in a pipe. The second time was leaking back to the tank.
If you are able to hook to city water, if it’s a check water valve, the fresh water tank will leak out the overflow. If it’s not, you’ll find a big leak in your trailer.
For the check valve, I opted to just replace the pump.
chrisski is offline   Reply With Quote
Old 06-15-2024, 07:01 PM   #4
Pulled the pump out and put new diaphragms in it from a old pump I had it’s not doing in any more
Thanks guys
Old 06-15-2024, 07:05 PM   #5
Correction it’s still doing it just about every 10 minutes now
Old 06-15-2024, 07:32 PM   #6
I traced the pipes as best as I could. Pulled the drawers also looking for pipes behind them. I finally pulled panels and found the leak.
Could also be under the Rv floor and above the plastic cardboard .
The pipes in the RV are only rated to 100 psi. I always use a pressure regulator for the city water when I found my house water pressure in excess of 100.
Old 06-16-2024, 04:31 PM   #7
Showermi$er ?
Originally Posted by Superstroker1 View Post
Correction itís still doing it just about every 10 minutes now
One user, NJKris, reported that his unit has the ShowerMi$er feature. If it is not COMPLETELY turned off, it will cycle water from the pump, through the valve, and back to the fresh water tank. There will be no evidence of a leak. The good news is that the fix takes just a few seconds to fully close the valve.
Does your RV have a ShowerMi$er?
Larry
Larry-NC is online now   Reply With Quote
Old 06-16-2024, 05:04 PM   #8
bikendan's Avatar
Pretty sure that Shower Misers were not installed on a 2015 Roo/Shamrock 23SS.
Old 06-16-2024, 05:46 PM   #9
Check the backflow check in the outside hose connection. Sometimes a piece of trash or sand causes the backcheck to not seat properly. This can cause a loss of system pressure and a resulting pump "on" to re-establish operating pressure.
Larry WB4WSA
2017 Microlite 25KS
2006 F350 SD CC 6.0
wlstroud is offline   Reply With Quote
