Originally Posted by sgreats
I recently purchased a portable waste tank for my ROO 233S but realized the inlet for the tank is higher than the outlet of the Roo. I was hoping someone could provide a recommendation for a tank that is compatible with my Roo.
Put
RV Sewage Tote into Google and then click
Images at the top. You might be able to find a low-slung unit.
This surprises me though. Your outlet has to be high enough for road clearance. Pretty sure most totes are lower than that, even though the hose dips lower.
Here is my finishing-up procedure:
When I finish draining, the hose (a real short one) has filled with water in the dip between the outlet and tote.
First I lift the hose, starting at the outlet and working, hand-over-hand to the tank to drain the dip towards the tote. I do this a few times.
Then I close the black tank valve.
Then I disconnect at the outlet and lift that end straight up, to drain the hose into the tote.
Then disconnect the other end of the hose and stow it.
Cap the tote, hook it to the golf cart, and take it to the dump station.
