looks like you have the two 6v batteries wired correctly, in series, but when changing batteries, yes, it's quite likely a fuse breaker tripped(there may actually be two 'buttons' to push to reset this), such as the one you show, or the main 'reverse polarity' fuse(s) in the RV's fuse panel broke.
Check, with a Voltmeter, that you are indeed getting 12volts from the batteries - then check the fuse breaker on the hitch, then the fuse panel inside. I had a similar issue, and come to find out it was a bad cell within my battery, which, when a load is applied, fails to the point that the 12v system doesn't receive the appropriate power, and everything is lost.
The Turners...
