Old 09-17-2020, 07:18 PM   #1
Radio
Hi I am new to the group .
We just purchased a 2016 Rockwood Roo 21 DK and there does not seem to be any power to the stereo . The previous owner states it worked the last time he used the camper . The fuse looks to be good . Any ideas ?
SueC is offline   Reply With Quote
Old 09-17-2020, 07:22 PM   #2
Fuse in breaker panel, or fuse in-line in the stereo itself ?
TheWolfPaq82 is offline   Reply With Quote
Old 09-17-2020, 08:35 PM   #3
Now a "Top Member"
EdJunior's Avatar
As TheWolfPaq says, it could be an in-line fuse. You may have to pull the stereo from the cabinet to find this fuse.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Old 09-18-2020, 01:59 PM   #4
Retired Panpsychist
Theo's Avatar
I discovered something in our Roo 23IKSS that may apply here. If you have a disconnect switch (ours is mounted under our LP tanks), look for a yellow wire attached to the battery side of the disconnect switch. On our Roo, that is the wire that powers the radio. Follow the wire for a little bit and you may find an in-line auto-type fuse. Check to see if that fuse has blown.
I guess FR wired ours that way so turning-off the disconnect switch did not power-off the radio and cause the station presets to be lost.
Theo & Carol
2007 GoldenDoodle ("Cooper")
2020 Rockwood Roo 23IKSS
2015 F-150 4WD XLT SCab, 5.0L, 3.73, 36gal, HD Towing Pkg (53A), 1,980lb Payload
Theo is online now   Reply With Quote
Old 09-19-2020, 08:34 AM   #5
Chuck_S's Avatar
Long shot: The OEM $7 radio in my Roo has speaker settings A and B but there are no B-speakers so the radio is silent if the switch has been accidentally set to B.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 09-19-2020, 11:43 AM   #6
njfishing's Avatar
Is it just the radio not working or do other things that run off the battery work like your inside light?
Gerry Z
2018 Forest River Heritage Glen 272RL
Ford F150 Lariat 3.5 Ecoboost Max Trailer Package
Curt Trutrack WDH
njfishing is offline   Reply With Quote
radio
