Originally Posted by Fullroo233s
There's a small reset button that I can only describe as "on the chimney". You'll access it through the outdoor panel and then it's behind the heat shield. Tiny black button right between the two wires. Something may have overheated. This is the safety shut off. If this works, double check rig is level
Looks sort of like this:
2011 Traverse LT, 3.6L, FWD
