Old 09-26-2020, 09:05 AM   #1
Rockwood Roo Basic Instructions
How do I sanitize, drain, and fill the holding tank for potable water (for use in campgrounds without water hook-ups)?
Linda Shuey is offline   Reply With Quote
Old 09-26-2020, 09:30 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. I put a cup of regular bleach in my potable water tank via the gravity fill that fill it to capacity turn on the pump to get the chlorinated water into the potable water lines and let it sit for 24 to 36 hours then drain and flush. use the search function at the top of the page there are tons of articles about how to do this. good luck
Retired Navy
2016 Flagstaff 26 FKWS
Old 09-26-2020, 09:44 AM   #3
6-8 hrs is MORE than enough time. I never went longer than 4 hrs on my TT's
TheWolfPaq82 is online now   Reply With Quote
Old 09-26-2020, 11:24 AM   #4
SeaDog's Avatar
I use what the well companies recommend to disinfect water. 1.5 ounces of house hold bleach per 10 gals of water for 8-24 hours. keep in mind this is for well water or after the tank has sat empty (over the winter) for a period of time city water is already has chlorine in it after initial shock treatment in spring I don't retreat because I use city water to fill. What you do or the time you take is dependent on the water quality you are using.
Retired Navy
Old 09-26-2020, 02:00 PM   #5
bikendan's Avatar
It would help if you posted which Roo model number you have, to help answer your questions.
Old 09-29-2020, 08:08 AM   #6
Greywater's Avatar
Basic instructions for sanitizing can be found in the online manual on the manufacturerís website.
https://forestriverinc.help/#/forest...9-6788C29717D3
Greywater is offline   Reply With Quote
rockwood, rockwood roo, roo
« 2007 Roo | Roo 183 »
