09-01-2017, 11:35 AM
Roo 21BD Running Generators and massive draw of electricity
Hello Guys,
new to the fourm. I own a 2016 Rockwood Roo 21BD Hybrid. Love it , but having an issue. I will run the generators ( twin Ryobi's ) and I keep tripping them. Here is my scenario as follows.
Sitting in trailer running A/C and have hot water heater turned off and also breaker turned off just to make sure there is no draw. Fridge running on Aux. Then after a few mins to an hour get a huge draw and trips the generators, the generators are 2000 watts each with running watts of 1800 each running in a parallel set up!. Also when plugging in to shore power the GFI will trip.
I am pulling out the rest of my hair trying to figure out why this is happening.
Has anyone had this issue ? Or know what the heck is going on? Or is this a common thing and is there a work a round? Please be so kind to help me out with solid info. if anyone has it out there!
09-01-2017, 01:14 PM
PhD, Common Sense
Do you think the surge in draw when the compressor kicks on is tripping the breakers?
09-01-2017, 01:20 PM
No ....the A/C i have running on the lowest setting and the compressor is running.it's weird... I dont get why it is doing this..... Like right now I have been in the trailer for a while now and everything is working fine now .....I'm beginning to think its one of my Generators is deffective.....probably going to purchase a new generator... like the Preditor from Harbor Freight....
09-01-2017, 01:23 PM
PhD, Common Sense
Well, if the compressor is running continuously, and not just the fan, then it is not the surge when the compressor comes on that is the problem.
09-01-2017, 01:25 PM
Yes I think your right......I'll give it a try and see what happens and post an update in a few weeks.....Thank you so very much!
09-01-2017, 01:55 PM
If you are using shore power and the GFI trips then it probably is not the generators.
2017 Flagstaff Shamrock 21ss pulled by a 2007 Ford F150 XLT 4X4
09-01-2017, 01:58 PM
Yep i get that....but when plugged in to shore power ....why would the GFI trip? its weird....this happens when the coach is stored and happens when camping and plugged in to shore power or using Generators
09-01-2017, 02:28 PM
I have a 3500 watt inverter which was giving me problems similar to yours except that the TT worked fine on shore power. A new control unit for the inverter fixed the problem. However, i would seem to me that because you are having a problem while using shore power and the inverter that the problem would be in the TT. It is possible that the breaker in the inverter is more sensitive or a trips at less current than the GFI. One thing you may want to try is turn all your breakers off in the TT and then plug into shore power, if it does not trip the GFI then turn on the breakers one at a time to try to isolate the problem to a spesific circuit.
09-01-2017, 02:29 PM
09-01-2017, 02:32 PM
Thank you .....I dont mean to sound like an idoit ....what do you mean by 'TT" and your idea sounds like a great way to use process of elimination to figure the problem out...
09-01-2017, 02:36 PM
When you say shore power, is it a 30 or 50amp service? If it is only a 15 or 20 amp circuit, you can trip the GFCI due to too much draw.
Old- 2002 21 Roo
New- 2015 Shamrock 23 IKSS
TV- 2010 Nissan Titan CC
09-01-2017, 02:39 PM
Ohhh OK...My house is 50 amp service ...I use a 50 to 30 amp adapter....
09-01-2017, 03:22 PM
I understand, I am also new to this forum and do not know most of the initals used but I have learned that TT stands for Travel Trailer. If you can find it there is also a large list of initials used, although not complete, that can be printed out. A lot of times I find, especially with electrical problems, the process of elimination is the fastest/only way to find the cause of problems.
09-01-2017, 03:31 PM
Thank you .....I will work on it and see if i can figure it out by process of elimination ....Thank you again Bacchus!
09-01-2017, 06:33 PM
TT-travel trailer, HTT-hybrid travel trailer, MH-motorhome
DW-dear/darn/darling wife, DH-dear/darn/darling husband
WH-water heater, a/c-air conditioner, TV-tow vehicle, tv-television, SOB-some other brand, FW-fresh water are a few common ones.
09-01-2017, 06:36 PM
Thank you !
09-02-2017, 12:06 AM
just to explain a bit about your Roo electrical service...
RV's typically have either 50 AMP or 30 AMP plugs that will fit into campground pedestals. Unless you have had an outlet added to your home, you do not have either 30 or 50 AMP RV plugs.
50 AMP RV plugs have 4 prongs and 30 AMP RV plugs have 3 prongs. see first two pictures below. These are both 120 V RV service plugs, not to be confused with a 30 AMP 240 V dryer or range plug.
I think you have 30 AMP service to the camper plug and use a 15 AMP household adapter to the 30 AMP trailer plug.
see third picture below
2014 Shamrock 183
09-02-2017, 09:28 PM
Can't help you with generators but congrats on your 21bd. We have a 2015 21bd and absolutely love it. We are on our 2nd cross country trip from Md. and by the time we return home we will have traveled a total of 16,000 miles. Enjoy
2 Old Geezers
1 Labradorable
2018 Dodge Ram 2500
2015 Roo 21BD-L'ABode
09-02-2017, 10:08 PM
Originally Posted by indnetsol
Hello Guys,
OK, lets start fresh.
1. When you say "Then after a few mins to an hour get a huge draw and trips the generators" do you mean that the GFI outlets on the actual generators are tripping and you have to reset them?
2. When you say " Also when plugging in to shore power the GFI will trip." do you mean a GFI receptacle inside the camper that has to be reset at the outlet?
If so, how long has this been going on?
3. Do you have an electric water heater, or is it Propane only?
09-06-2017, 10:55 AM
When running our 15k A/C on twin 2000w Generac generators, sometimes the converter will trip out the generator. I notice if I turn off the converter breaker, I don't get that problem. Also, I put my frig on LP only so the only load is the A/C. I haven't figured out why yet, but if I run in Turbo, no trip issue, in Standard, sometimes and in ECO mode, 5-10mins.
2016 Rockwood 2702WS
2016 Chevy 2500HD Duramax 4x4 High Country
