Dogs popped out bottom door screen. Thinking of replacing with plexiglass, using the existing 4 screw holes then sealing with silicon adhesive. Thoughts?
not sure if this would be the look you want but HomeDepot sells decorative metal panels in various sizes that might be good for the bottom portion of the door to give a little air movement...
Following as we may need a solution as well. I’m thinking the plexi would work but i like the idea of using the Home Depot idea above or even multiple horizontal aluminum bars that would protect the screen but still leave air flow and visibility
