11-07-2022, 01:01 PM
#21
Scoundrel
Battery disconnect switch....
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
11-07-2022, 01:02 PM
#22
Originally Posted by wmtire
Without being connected to a form of shore power, you will have what are called parasitic draws on the battery. Your CO detector is always on, your radio may also draw some power to maintain presets, etc.
If your RV does not have a battery disconnect, you may want to consider installing one, or just disconnecting your negative battery cable when not at the RV to prevent these parasitic draws.
If this is your first RV, then I recommend reading the info at this link as it is aimed at the new owners.
https://www.forestriverforums.com/fo...ts-157524.html
Yes, we've had a couple of very basic older popups...so our first RV. Thank you for the article. Very helpful.
11-07-2022, 01:06 PM
#23
Originally Posted by Reverse_snowbird
You said that you 'checked on the camper', so I'm going to assume (probably a bad idea) that you've got it in storage without electrical service.
We have it stored in our barn...there is shore power, but we had unplugged it last weekend when we parked it on Sunday.
11-07-2022, 01:09 PM
#24
We are still looking for our battery disconnect switch...definitely don't have anything that looks like this. Maybe we don't have one? I've heard we can just disconnect the negative battery cable so we'll do that for now.
11-07-2022, 01:11 PM
#25
Doubtful your 2011 Roo ever had a battery switch. Pulling the Negative cable every time you park not in use will get very old. Just put a switch there. Every boat store including Amazon has them.
-- Chuck
11-10-2022, 09:25 PM
#26
I have a 2014 Roo 233S. On mine, the battery switch is a push-pull device located near the converter. Pushed in, the battery is disconnected. Pulled out, the battery is connected (yours my be different, but look around anyway and see if you have something like this.) If you disconnect the battery with the switch, I believe it disconnects the the gas detector also, so it should save your battery charge pretty well. On my camper, I think the slide takes its power directly from the battery cable, so that may not be disconnected. Good luck, and enjoy your hybrid. I love mine.
____________
2014 Roo 233S
2023 Silverado 1500 Crew cab, 2.7L 4 cyl.
Oneonta NY
11-11-2022, 01:31 AM
#27
I have a 2014 Shamrock/Roo 183... I have wondered for years... does this disconnect switch actually disconnect the LP detector AND the radio? How about the front jack? I think the jack is connected directly to the battery. I know it disconnects the awning motor... from experience.
2014 Shamrock 183
11-11-2022, 07:00 AM
#28
On mine, the jack is connected to the battery with its own wire (my Roo didn't come with an electric jack, I installed my own.) I remove my batteries for the winter and put them on a special charger, so I can't use the jack to move the trailer if I want to. Couldn't hitch or unhitch without the jack. I bolted the camper's battery cable to the jack's power wire and taped it up. Now, if I plug the converter into power during the winter, and connect the battery disconnect switch, the jack works because the converter will power it.
____________
2014 Roo 233S
Oneonta NY
11-11-2022, 07:20 AM
#29
I believe the RVIA * code requires the LP detector to be connected directly to the battery and convenience requires the radio to be likewise connected to preserve its memory. Easy enough to check on your camper though...
* RV Industry Association
-- Chuck
11-11-2022, 09:10 AM
#30
FWIW, new Roo's (at least my 235S) radios are behind/after the on-frame disconnect switch. No power reaches the radio with the trailer "turned off."
2022 Rockwood Roo 235S
15kBTU AC; 12v fridge; 1kW roof-mounted solar panels; 80 amp MPPT charge controller; 3,500w pure sine wave inverter; 30a automatic transfer switch; MicroAir EasyStart, 600ah Chins LiFePo; Honda EU2200i (with Hutch Mountain propane conversion kit) gathering dust in the storage unit.
11-19-2022, 04:20 PM
#31
Another 2011 233S owner here. That year trailer did not come with a battery disconnect switch. You will either have to disconnect negative post or install a disconnect switch. I installed mine on the negative side right up near the battery.
2014 Chevy Silverado
2011 Rockwood Roo 233S
