Old 02-01-2023, 06:53 PM   #21
Originally Posted by Larry-NC View Post
Ah. On the one I'm doing, the roof decking was nailed to the trusses. There is pink fiberglass insulation beneath. This difference may be because ours is a 22' unit with no air conditioning ducts; just dumps in the center.
The worst of the water intrusion was where the awning anchors span the gutters. That causes the gutters to clog and overflow. In turn the water follows the lag screws that hold the anchors on. A widely practiced bad design.
Time for new decking
JdGriswold is offline   Reply With Quote
Old 02-01-2023, 07:29 PM   #22
In one piece
Try to take each panel off in one piece so you can cut the replacement to the same size with the cutouts in the same place.
In my case, some of the decking was good and stays in place. I can but the replacements against it to assure good end to end placements.
I made small marks on the siding above/behind where the rain gutter goes at the center of each truss so I could snap a chalk line across each panel.
And of course, I started screwing each panel down in the center and worked my way to the sides to get gap-free contact with the arched truss surfaces.
Larry
Larry-NC is offline   Reply With Quote
Old 02-03-2023, 09:28 AM   #23
That would be a great idea if I had trusses it is all styrofoam kinds scary thought I was gonna go thru the roof while tearing of the decking
Old 02-03-2023, 11:44 AM   #24
MillMitch's Avatar
Is that even a walkable roof? How can there be no trusses? The A/C unit would come through the roof on the first bump.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 02-03-2023, 12:30 PM   #25
Rhumblefish's Avatar
It's a walkable roof; the wood+foam arch forms a composite structure and is more than self-supporting. However, because you're messing with a structural component, you're definitely going to need to re-adhere/glue the new ply to the existing foam. I'd suspect the glue you use is going to need to be pretty specific performance in this application (I understand the factory vaccuum bags the entire roof for assembly, so whatever process/materials you go back with will have to yield a structure that has that level of adhesion/performance or better.
2022 Rockwood Roo 235S
15kBTU AC; 12v fridge; 1kW roof-mounted solar panels; 80 amp MPPT charge controller; 3,500w pure sine wave inverter; 30a automatic transfer switch; MicroAir EasyStart, 600ah Chins LiFePo; Honda EU2200i (with Hutch Mountain propane conversion kit) gathering dust in the storage unit.
Rhumblefish is offline   Reply With Quote
Old 02-03-2023, 02:02 PM   #26
Or...
Originally Posted by Rhumblefish View Post
It's a walkable roof; the wood+foam arch forms a composite structure and is more than self-supporting. However, because you're messing with a structural component, you're definitely going to need to re-adhere/glue the new ply to the existing foam. I'd suspect the glue you use is going to need to be pretty specific performance in this application (I understand the factory vacuum bags the entire roof for assembly, so whatever process/materials you go back with will have to yield a structure that has that level of adhesion/performance or better.
Or...put the new decking over the old decking.
Larry
Old 02-03-2023, 02:05 PM   #27
Not current
Not familiar with construction processes? Our congregation is in a building built in 1970. Much of it is flat roof.
Corrugated galvanized steel is placed over the beams.
6" of styrofoam over that.
Rubber membrane with lap sealant over that.
Gravel over that.
Yes, people walk on it, including the air-conditioner service people. I imagine there is framing beneath the air conditioners.
Larry
Old 02-07-2023, 07:19 PM   #28
Gravel over that.
Old 02-07-2023, 07:20 PM   #29
New decking is on
Old 03-05-2023, 03:14 PM   #30
Attachment 283718
New decking is on
Old 03-05-2023, 03:42 PM   #31
What's with the burned mark and sharp/rough edges at that spot? I wouldn't want the membrane wrapping over that if mine.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
roo, roof
