01-16-2023, 09:05 PM
Roof
Going to put new roof on my roo 233s any tips or tricks out there
01-17-2023, 09:32 AM
new membrane covering or gonna gut the entire roof rafters and all?
Your statement covers a lot of ground
2014 Shamrock 183
01-17-2023, 09:33 AM
New membrane
01-17-2023, 09:38 AM
I suppose I would question why you would do that and what year is the Roo
2014 Shamrock 183
01-17-2023, 09:40 AM
I would suggest that you go to youtube dot com and use the search term
rv roof replacement diy
for a number of videos on how to do this type of work for various membrane types
2014 Shamrock 183
01-17-2023, 09:48 AM
Yeah been doing that for about a month my kit just got here yesterday
01-18-2023, 11:14 AM
We're gonna want photos and details of your success!
-- Chuck
01-21-2023, 02:24 PM
-- Chuck
First pic
01-21-2023, 04:53 PM
The parts are always a good start.
-- Chuck
01-21-2023, 07:41 PM
Originally Posted by JdGriswold
First pic
So is it 'relaxing' to get rid of the fold marks?
2015 Dynamax REV 24TB class C
01-21-2023, 08:42 PM
A day or two...
A day or two in the hot sun, using a push broom as a squeegee BEFORE the contact cement is applied.
Our older trailer (DW's dowry) was had air staples every few inches on both sides covered by the rain gutters. I had to pry those out so I get get the membrane off.
My deconstruction of the assembly process is: - Guys on platforms on each side of the trailer.
- Spread the contact cement from the middle to one end.
- Put the membrane in the middle and pull it to one end.
- Working directly opposite one another, the two guys pull the membrane taut side-to-side and put a staple in each side.
- Continuing, the two guys pull the membrane side to side AND taut towards the end and put in the second set of staples, maybe 6" from the first.
- This repeats until they get to the end.
- Then they put staples across the end, under where the transition piece will be placed.
- Then they repeat the entire process from the middle to the other end.
My experience. I'm replacing roof decking and some truss on the older trailer.
Larry
01-22-2023, 01:04 PM
I live in Iowa so hot sun is not option but a heated shop is I decided to roll it up it will sit in heated shop hopefully I will start taking everything off next weekend
01-26-2023, 07:31 PM
We needed a new roof on our Salem 29rlls, since Camping World wouldn't honor our warranty, we had the roofing company that put on a flat roof on our house do it. They used the same membrane on our camper, $3500.00. Much thicker than RV membrane and should last a lot longer.
01-26-2023, 11:19 PM
Tip? Get someone who has done it before to help you.
Better tip? I replaced mine in October with FlexArmor...lifetime material. Tough stuff. Cost installed is comparable. It took them 2 days while I propped my feet up and slept.
01-27-2023, 08:57 AM
Originally Posted by garywilson
...It took them 2 days while I propped my feet up and slept.
Now THAT is the way to get projects DONE~!! Only improvement would have been feet propped up near a campfire with an Adult Beverage in hand!
Ed & Chris, Empty Nesters (missing Josh & Jaclyn)
along with Blue & Tessa, Cat Explorers!
2020 Rockwood Roo 235s
2019 F-250 Diesel 4x4 Super Duty
01-28-2023, 04:01 AM
Replacing roof membrane
I recommend the YouTube Channel "AZ Expert". This is a mobile tech who does a LOT of roof replacements - pretty horrific stuff, too. He's witty, but straight-up. Mostly, he does a lot of Winnebagos and MHs.
He also walks you through a lot of other repairs.
01-30-2023, 07:35 PM
Making progress
01-30-2023, 08:24 PM
The white part
Making progress
Tell us about the white part. Water-logged decking?
Let me guess. Was there an awning bracket on the side near there?
Larry
01-30-2023, 09:41 PM
No I decided I am going to replace all of the wood on top I just ripped out a chunk. It is glued to styrofoam no staples I feel the surface will be uneven if I replace just the bad spots because part of the styrofoam is coming off with the decking
01-31-2023, 09:46 AM
Ah...
Ah. On the one I'm doing, the roof decking was nailed to the trusses. There is pink fiberglass insulation beneath. This difference may be because ours is a 22' unit with no air conditioning ducts; just dumps in the center.
The worst of the water intrusion was where the awning anchors span the gutters. That causes the gutters to clog and overflow. In turn the water follows the lag screws that hold the anchors on. A widely practiced bad design.
Larry
