Hello, on our 21ss our slide out goes out just fine but when pressing the switch to slide back in it sometimes doesnt do anything. No motor sound no movement our attempt to move. Sometimes pressing the out button then in it will work. suspect the switch. Anyone else with this problem.
Ron and Christine
It’s the switch, to make the DC motor go in the reverse direction you just need to reverse the polarity of the voltage going to the motor, which is done with the switch.
