For the repaid Id get apiece of canvas 3X the size of the tear. Cut it in a circle.
Then use Shoe Goo or Lexel to coat one side fully and completely to a thickness of about 1/8" or so.
Then apply it to the tear with a piece of wax paper on top so you can press without getting the adhesive on yourself.
Have someone on the other side hold something hard and flat on the other side so you have something to press against. You are trying to get the adhesive into and hold onto the fabric of both the patch and the piece being repaired.
When the adhesive cures you will have a flexible waterproof repair.
PS, if some of the adhesive leaks from around the edges of the patch....LEAVE IT ALONE!!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
