07-17-2020, 07:54 PM
Stripped Screw on Front Bed Door
Need help
Last weekend when I went to close the front bunk this screw apparently is stripped. Tried to tighten and it just turns. I am a bit nervous fixing this since this is part of what keeps the door locked. There is not much room to work with either. How should I fix this? I do have some thoughts in mind but before I start working on it thought maybe I would reach out to all of you for advise. Or should I just call someone to come out? It's currently in an RV park for the summer. I cant close the door because of this right now. The picture is sideways but, hopefully you get the idea.
Very much appriciate any advise. Thank you!!
07-17-2020, 08:07 PM
Fixed a lot of that with wood glue and toothpicks.
Add glue. Cram the hole full with tooth picks. Or gently tapered Dowel rod.
Insert screw. Let dry overnight.
07-17-2020, 09:15 PM
Thank you for replying so quickly. I had thought of that but wasn't sure if wood was the way to go. Would it help if I got a bit longer screw as well?
07-17-2020, 10:19 PM
Id follow advice above. I prefer using wooden matches (break the heads off of course- rather than toothpicks. Be sure to use a waterproof glue and jam the wood in tight. I haven't found it necessary to let the glue dry very long prior to reinserting the screw. If easier, for you, a screw of slightly larger diameter would probably work but I'd try that second.
The glue and stick filling the hole is least likely to cause any additional problems.
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equal-i-zer WDH, 1809 lb payload
07-17-2020, 10:30 PM
Without knowing what’s back there I would not go to a longer screw. Glue, toothpicks have worked for me.
2015 silverback 31IK
2023 f350
07-17-2020, 11:05 PM
I was concerned about that as well. I will stay with the same size and the match sticks.
Thank you for the help!
07-17-2020, 11:31 PM
It's a Luan sandwich construction panel.
07-18-2020, 01:29 PM
Need help
I would go with a tee nut. They come with and without prongs to sink into and grip one surface or without prongs so not to mare the surface. Available at any Lowe's or HD. Search "Tee Nut" and you can find a picture. Sorry for the long URL's
https://www.lowes.com/pd/Hillman-3-8...B&gclsrc=aw.ds
https://www.lowes.com/pd/Hillman-2-C...B&gclsrc=aw.ds
07-18-2020, 08:32 PM
Umm...no
Originally Posted by bzac1954
Tee nuts are applied from the BACK side. You drill all the way through the media and insert the Tee nut from the back side, the screw in a machine screw from the FRONT side. I do not believe the OP has access to the back side in this case.
Some instances (e.g., metal thicker than sheet metal) are suitable for Rivnuts. These are essentially a pop-rivet with a threaded core. But this in instance the media is soft luan plywood. Rivnuts would not work.
If there's some thickness behind the luan plywood, I favor plastic anchors. You can get them with and without flanges at the big end. Use the ones without flanges if it's important that the fixture mount flush to the surface. The one without flanges are a little trickier to use. It helps to insert the screw the first time without the fixture in place, to expand the anchor. Then remove the screw and mount the fixture by turning the screw without applying much pressure on the tool.
Larry
07-18-2020, 10:03 PM
RV There Yet?
I like a polyurethane glue like “gorilla glue”. Wet the surface, apply glue to damp toothpicks, fill hole with glue coated toothpicks. Insert screw and tighten. Done and done. The glue will expand a bit and grip all sorts of surfaces.
07-18-2020, 10:14 PM
Hot Dog Slayer
You could also try a butterfly anchor, if the wood and glue doesn't work.
I've fixed plenty of problems using both options.
Two roads diverged in a wood and I took the one less traveled by.......now try backing your trailer out of that one!
2016 Forest River Microlite 21DS
2019 Ram 1500 Pearl Red Limited
