04-28-2018, 09:39 AM
Tire pressure for Roo 233s?
What’s the recommended pressure? Thx
04-28-2018, 10:50 AM
Check the certification label on the outside of your trailer. It tells you what pressure to use with the factory tire size.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
04-28-2018, 11:08 AM
guessing that you have load range C tires on your trailer from the factory, therefore max air in all tires according to sidewall is probably 40#
EDIT
sorry make that 50#
2014 Shamrock 183
04-28-2018, 11:13 AM
LRC ST tires have max load at 50psi.
2013 Shamrock 21SS
04-28-2018, 11:15 AM
50 psi is what my Coachmen Apex recommends.....
Gerard
2017 Coachmen Apex 269RBKS with Summit Pkg.
2014 Ford Expedition with factory installed HD tow pkg.
Blue Ox SwayPro WDH
04-28-2018, 11:16 AM
I have a 2015 233s. Factory original load range C tires call for 50 psi. cold.
I just replaced with GY Endurance LRD tires and am running 56 psi cold.
04-28-2018, 12:36 PM
I always run the tires at max pressure. On the TV also.
As a former tireman, the most common tire wear issue is under inflation.
04-29-2018, 06:12 AM
X2
04-30-2018, 03:09 PM
Also really put them at that max when cold first thing in the morning. It doesn't matter past that point how high the pressures get when hot. Some people will check again at a rest stop after running during a 100 degree summer day and freak out when the pressure is pretty high. That's how its supposed to go. 50 psi isn't the max pressure, it's the max pressure cold, they dont list a max hot pressure because assuming you are driving on Earth, if you start max pressure cold you will never, ever exceed the real busting max pressure, not even close.
