Old 09-14-2020, 07:47 AM   #1
Toilet leak
We have a 2007 Rockwood roo 21ss and notice a small amount over water near the front base of the toilet. Does this mean the flush seal is going bad or is there another seal at the floor as well that could be going bad. Any advice would be greatly appreciated.
Zeus1972 is offline   Reply With Quote
Old 09-14-2020, 08:10 AM   #2
Scoundrel
HangDiver's Avatar
Reach behind the toilet and feel the line into the valve in the back of the toilet. Sometimes those valves crack and leak. The water you see may be traveling from the rear of the toilet. Check the easy stuff first.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
HangDiver is online now   Reply With Quote
Old 09-14-2020, 08:15 AM   #3
Head Rambler
Do you know what model toilet you have?
There have been lots of problems with the middle seal on the Dometic 300 model.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 09-14-2020, 02:37 PM   #4
Not sure we will be other there again this weekend I will take a look
Old 09-15-2020, 01:58 PM   #5
bikendan's Avatar
Was the Dometic 300 even around in 2006?
Equalizer WDH
Old 09-15-2020, 02:02 PM   #6
So my so went out there today turned the water back on flushed a few times and nothing no water on the floor or anywhere. I asked what make and model and he couldnít find the information on it. I looked in the book and nothing there either. I am at a loss.
Old 09-15-2020, 02:10 PM   #7
We had a Thetford that would leak around where the foot valve went into the toilet body. That was on a 2011 Flagstaff.
KKonyha is offline   Reply With Quote
Old 09-15-2020, 02:12 PM   #8
This toilet doesnít have a foot valve the handle for flushing is along the back of the seat right hand side . Iím just baffled.
Old 09-15-2020, 04:05 PM   #9
We had the same toilet and would occasionally have water on the floor. It was leaking somewhere around the flush valve, never did find exactly where it was coming from. Stopped leaking one day and eventually sold the trailer.
phipps33 is offline   Reply With Quote
Old 09-15-2020, 07:16 PM   #10
cdog7201
Send a message via AIM to cdog7201
toiletleak
when flushing is the water shooting over the rim and running down the outside to the floor .I have seen that happen if the water tub gets out of alignment.
cdog7201 is offline   Reply With Quote
Old 09-15-2020, 09:59 PM   #11
If your toilet is leaking when someone is setting on it, it might be the seals between the top and bottom of the toilet. If you have the two part toilet and the seals go bad you might notice the water in the toilet slowly drains away over time. I am not sure which toilet you have but there should be a tag on the back side that tells you which toilet you have. If the seals, {2 of them} are bad they are easy to replace and can be bought from Amazon once you know which toilet you have.
Job is messy, so wear gloves, but only takes about 15 min.s to a half hour to do.
Google search has a lot of information about rv toilets.
Wattsworld is offline   Reply With Quote
Old 09-16-2020, 08:55 AM   #12
Head Rambler
Does your toilet look like this one?
If it does, that's a Thetford Aqua Magic V.
Here's the manual for it. Owners Manual Aqua Magic-V
It has a parts breakdown in it.
Gotta go campin!
leak
