Hello, I was trying to connect my TV to the DVD player that is in my camper (2011 Roo 233s), but I'm not having any luck. I can get the antenna to hook up from the panel with two coaxial connections, using the lower labelled as "ANT", but I can't seem to figure out how to connect to the DVD output
? I'm assuming that it is coming out of the closer of the two panels (see pic) which looks like a single coaxial connection, but it's actually a little longer and the threads are set a little deeper, so when I try to connect a standard female coax end it can't reach the threads. Does anyone know if this is the DVD output and if so, what type of connection is this? Some variation of a coaxial that I need a special cable for? Thanks in advance for any help!
Side note, my FM reception is awful...is this a known issue with these receivers and if so, any easy/cheap solutions?
