04-29-2015, 04:24 PM
Using slide outs at roadside stops
Once or twice I was able to extend the kitchen on our 23IKSS while at a rest stop. It was just enough to get to the bathroom and refrigerator. Then another time it came out a bit but I could not get it back. Luckily it was only about 2" and we didn't have far to go to get electricity.
Is it possible to extend the slide out at least a little bit when stopped at a rest area? Maybe I was just lucky the first times but would like to know what others have done.
Bonnie
04-29-2015, 06:00 PM
Bonnie, the slide motor should work just with battery power. Connection to 110v shore power is not required. At our dealership the sales staff used a portable starting pack to power the slides for viewing, so you should have no issue with putting the slide in and out at a rest stop. Not sure what is causing your difficulty, but start with checking the available voltage at your battery.
HTH
Stu
Stu
Calgary AB
2014 Roo 233S
2011 Ford Econoline Club Wagon
04-29-2015, 06:24 PM
I agree with Stu. Your best bet is to first check the health of your battery. Even a small group 24 marine battery should be able to handle the light duty you are asking for with this slide (especially if you had started out with it fully charged). It's possible the slide is binding or is out of alignment and causing problems, but you would know this because it would also struggle on shore power. I'd check the battery first.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
04-29-2015, 06:27 PM
Also, Bonnie, you might want to familiarize yourself with the manual close procedure. You never know when you need to close it tight and don't have the power to do it. Let us know if you need any details on that (or on how to check your battery).
Scott
2012 Shamrock 233S
04-29-2015, 07:29 PM
Thank you guys for the information. I wanted to make sure this was possible with battery power only. I'll check it out tomorrow and make sure I have power when needed. The trailer is plugged in now at home so I'll unplug and check this out. I'm sure I can find the information on manual operation in the book.
04-29-2015, 11:10 PM
I have done this battery power only with no problem.
Velosprout
2014 F150 SCrew 4x4 Max Tow Heavy Duty Payload 3.5 Ecoboost 6.5' bed Ingot Metallic Silver
2015 Rockwood Roo 21SS
04-30-2015, 04:49 AM
This type of slide is designed to be only opened and closed FULLY. It has electronic controls that will get out of adjustment if not operated properly. There are many videos on UTube. It is a Schwintek slide.
Les & Heidi Kramer
2021 Jayco Melbourne 24L
Olmsted Township, OH
04-30-2015, 05:57 PM
According to slide makers you should never partially deploy your slide out. It messes up the motor sync and will cause problems.
2015 Roo 23IKSS
2016 F150 SuperCrew 3.5 EcoBoost
04-30-2015, 06:08 PM
I did not know about partial deployment, thank you guys. My husband is charging the battery now and we will try to operate the slide again tomorrow.
04-30-2015, 06:15 PM
I have opened my slide partially here and there for 6 yrs now and no issues. Is it limited to a certain manufacturer?
2012 F350 Lariat CC SRW 6.7L Powerstroke
04-30-2015, 06:32 PM
I believe they are talking about the Schwintek slideout system which should always be opened and closed fully.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
04-30-2015, 07:33 PM
Yes, the OP identified there unit as a 23IKSS - kitchen slide which is a Schwintek, at least on mine.
2015 Roo 23IKSS
04-30-2015, 08:24 PM
2nd battery
My RV tech saw my added battery and said "that's smart the slides wear out a single battery quickly"
might be worth considering.
04-30-2015, 11:45 PM
It seems to me that would be true only if the owner allowed the battery to discharge excessively. I doubt that a single in/out cycle would lead to failure.
Sent from my phone using Tapatalk.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
05-01-2015, 03:44 AM
We have been hooked up to 110 for the past 2 weeks, shouldn't the battery be charged up?
Does the battery get charged while towing the trailer?
Maybe my DH crossed some wires when he hooked it back up a while ago and we just didn't notice until now.
Bonnie
05-01-2015, 05:02 AM
Yes It should be. On AC, your trailer's converter charges the battery. I assume Shamrock still specs WFCO. All WFCO power converters are automatic three-stage chargers.
Somewhat. It takes a fair amount of driving to charge a low battery.
Have you checked your batteries voltage and was it low?
Scott
2012 Shamrock 233S
05-01-2015, 05:20 AM
During our walkthrough the tech mentioned that its best to be hooked to shore power or the running TV to decrease the battery drain while running the slide.
your 7 pin should have a hot wire feeding 12V power while running.
Retired Paramedic
2020 FSX 280RT
2005 Silverado 1500 Ext cab 5.3 H.O.
2011 HD Road King
Nights camped since 2019.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
05-01-2015, 07:04 AM
My DH plans to get a gizmo to check voltage today.
Thanks all
Bonnie and Rich
Oconomowoc
Winston (Rat Terrier)
Digby (Lhasa Apso)
2014 Shamrock 23IKSS
05-01-2015, 07:11 AM
Thanks all
May I suggest.
Alternator/Battery Tester
05-01-2015, 07:18 AM
Thanks all
Here is a good read on 12v for your husband.
The 12volt Side of Life (Part 1)
