Old 06-17-2021, 02:34 PM   #1
Water toilet
Got some toilet repair to perform on my 2016 Roo 19 and was wondering how to turn off the water to the toilet?
brl1956 is offline   Reply With Quote
Old 06-17-2021, 02:50 PM   #2
Blackrock's Avatar
Either turn off the pump or turn off the city water. I have never seen a separate shutoff.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
Blackrock is offline   Reply With Quote
Old 06-17-2021, 03:31 PM   #3
I remember seeing one once but it wasn't factory installed. I believe someone posted a pic of it here.
Iwritecode is offline   Reply With Quote
Old 06-17-2021, 03:41 PM   #4
never seen one with cut off. wrap a rag around hose.
Thomas ho is offline   Reply With Quote
Old 06-17-2021, 03:42 PM   #5
This one?
https://www.forestriverforums.com/fo...up-137323.html
yukongold is offline   Reply With Quote
Old 06-17-2021, 03:44 PM   #6
Kanadian Kamper
kenandterry's Avatar
Most people install their own shut off tap for the toilet, the first time they’re doing any substantial work. If not…..just shut off the supply for the entire rig.
Lots to choose from
https://www.google.com/search?q=rv+i...CA694&hl=en-US
Ken and Terry
2018 Sunseeker 2430S-CD
and if we ever need it, can be pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 06-17-2021, 03:47 PM   #7
GravelRider's Avatar
After shutting off water/turning off the pump, turn on a sink and let some water run to release built-up pressure out of the lines before doing work.
GravelRider is offline   Reply With Quote
Old 06-17-2021, 04:16 PM   #8
Originally Posted by yukongold View Post
That's one but I was thinking the one I remembered was more recent.
Anyway, it's not a completely uncommon upgrade for RVs as a do-it-yourself project.
Old 06-17-2021, 04:33 PM   #9
I turned off the water pump at the switch panel, but it keeps on pumping water to the toilet. Is there another on/off switch on the pump itself?
Old 06-17-2021, 04:37 PM   #10
Just Tryin' to Help
cboss's Avatar
Are you hooked up to "city water". If so, turn off the valve at the water pedestal.
You do not need the water pump on if hooked up to "city water".
Craig & Cath
2017 Ford F250 Lariat, 6.2 gas (2022 F250 Lariat 7.3 gas with 10 speed Xmsn on order)
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2015(retirement): 1044
cboss is offline   Reply With Quote
Old 06-17-2021, 05:40 PM   #11
Nope, no city water and only a small amount of water from the water tank. I don't get it that the toilet keeps getting water from ?
Old 06-17-2021, 06:46 PM   #12
Are you hearing the pump turn on and pump water?
Old 06-17-2021, 06:49 PM   #13
its syphoning down from upper hoses, open low point drains. there will still be some , also from water heater but i dont recall if cold " in" is hooked to top of tank or bottom.
Old 06-17-2021, 07:12 PM   #14
Well, I got the valve replaced with only a small amount of water spilled. Thanks for all of your help!
Old 06-17-2021, 07:29 PM   #15
This is the toilet valve. The Beech Lane Upgraded Water Valve Kit 385311641 for Dometic Toilets 300, 310, and 320- Freeze Resistant Technology, Patent Pending Double O Ring Safeguards Against Leaks.
It costs more than others at $19.99 on Amazon, but is freeze resistant and has a double O ring.
Name:	Trailer toilet valve.PNG
Old 06-18-2021, 06:56 AM   #16
Chuck_S's Avatar
There are no separate valves for ANY of the water lines in my Roo. None. Not sure of any special need for one at the toilet or anywhere else. But if the plumbing is in pieces it's dirt simple to put one in. Just something to be Off when it should be On though.
-- Chuck
Chuck_S is offline   Reply With Quote
water
