03-03-2021, 09:17 PM
WD Hitch specific to 233S
Good evening everyone!
We take delivery of our 2021 Shamrock 233S pretty soon and I want to get a WD hitch with sway control. Have been looking at the Curt TruTrac but was curious to what others have been running.
Tow vehicle is a 2020 Ram 2500, 6'4" bed, 6.4 Hemi with 3.73 gears.
I know everyones weights will be different based on fluids and all the other stuff we bring along but trying to ball park it here. For the Curt TruTrac, they offer 3 different models based on trailer weight and tongue weight.
Please, go easy on me, but I do appreciate any help.
P.S. I know there is a towing sub-section but posted here based on the hybrid specific forum.
Thanks again!
03-03-2021, 11:47 PM
I use an Anderson WDH. It has sway control. I like that it half the weight of a spring bar WDH and that I can adjust it quickly when I change my load. If I decide to carry a full fresh tank instead of only 10 gallons.
There are several other advantages too. Do a search and you will see it discussed many times.
Hobienick
2022 Grand Design Imagine 2800BH
2020 Rockwood Roo 19 (Sold Jul 2022)
2012 F150 SuperCrew Ecoboost
03-04-2021, 05:38 AM
I also have a 233s and Ram 2500, previously a Ram 1500 and have towed my rig thousands of miles. I use an E4 Equalizer with 10,000 lb bars and have been extremely happy with it.
03-04-2021, 06:44 AM
I use a Husky Centerline TS to tow my 233s. Couldn't be happier with it.
Kevin, Julie (DW), 5 kids
2017 Roo 233s towed with 2016 Dodge RAM 2500
03-04-2021, 10:19 AM
I used the same WDH for 10 years, to pull my Roo 23SS.
Still using it to pull my current TT, for an additional 5 years.
03-04-2021, 12:37 PM
Like others I can personally recommend the Equalizer (think it's called the E4 now) with 10K bars. Been on my Roo 23SS since 2005 -- in her 17th season at present. Maintenance consists of an annual bolt torque and clean and touch up the paint. Ran this on an '02 Explorer and '07 and '17 Expeditions.
-- Chuck
03-04-2021, 01:58 PM
Hi All
Like DuckSlayer, I recently purchased a 233S and have had it sitting in my driveway since Nov.
I have been looking into WDHs and after a lot of research I have settled on the E2 6000. We were going to go with the E4, however we were told that it really is way to much for a 5K lb rig. I was told the extra weight would work against us and definitely not to go above a 8K lb setup.
Is this true? I would hate to get one that under-performs.
03-04-2021, 03:17 PM
But you don't have a 5000 pound rig, it's closer to 7000 pounds.
Roo 233S
Empty wt: 5063lbs
Cargo Cap 1587
Total: 6650lbs (and you'll be lucky to keep it to this weight with water, batteries, LP cylinders, etc.)
Tongue weight at 13%: 864 pounds. The "10K" WDH will handle 1000 pounds. As noted it's been working perfectly for me.
-- Chuck
03-04-2021, 04:09 PM
My model is a little older. GVWR 4500 and max cap 1600....not trying to split hairs. Going with the higher weight model would probably be advantageous. My question was a little more focused on the E2 vs the E4 for these lighter rigs.
I originally wanted the E4 but was talked out of it by a local dealership.
03-05-2021, 10:16 AM
Another vote for Equalizer E4. 10000 bars. It's better to more than not enough with lower weight bars. Pulls straight, true, no sway. Wind & oncoming semi's don't bother me.
2014 Chevy Silverado
2011 Rockwood Roo 233S
03-05-2021, 07:19 PM
I appreciate everyone’s responses and feedback!!! Based on a ton of different factors, I went with the Andersen hitch and I’m looking forward to seeing how it functions.
I guess if it doesn’t work out, I will sell it and go with the Equalizer!
Thanks again everyone!
