09-29-2019, 10:22 PM
#21
Originally Posted by TheWolfPaq82
Good lord, I see TT and 5vers everyday that are 2, 3, 4 even 6" off level. I'm happy if i'm within an inch or two.
He is referring to the front fender height change, not the level of the travel trailer.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
09-30-2019, 11:11 AM
#22
Originally Posted by D W
1/16"? My friend, you are there! I'd be willing to bet that if you did get to 0" it wouldn't make any difference.
Not only that, drive down the road a mile or two, then measure, and it most likely will be off a few fractions either way.
09-30-2019, 11:33 AM
#23
Grammar Pedant
As you know the goal is to be at least 50% back to normal without overshooting. In your case, normal is 37" and half way back would be 37 1/4". So, the optimal range should be 37 - 37 1/4".
As others have said, I wouldn't sweat the 1/16". I might measure it again after towing and such to see if that's a consistent measurement. If it started to grow, for some reason, to 1/8" and beyond, then I'd take the 15 minutes and adjust my WDH. But, I wouldn't do it for 1/16".
Former RV: 2018 Rockwood Mini Lite 2504S
09-30-2019, 12:16 PM
#24
yeah.......so was I. Passed a 5ver this morning that I think I could've walked under the front end and belly slide out the back.
09-30-2019, 01:06 PM
#25
Retired Old Fart
1/16" is pretty much about as good as it gets. NASA might design a hitch that is with 0.000001", but it would cost 10 million dollars and require a team of Doctorate level engineers to maintain it. Drive it and it should be fine.
And yes, if you measure it again after driving it will probably be a little different. Lots of moving parts involved in the process along with the levelness of the spot you are parked on.
Just the 2 of us in a...
"Currently between trailers"
Sold the 246RKS in 2023
10-02-2019, 01:56 PM
#26
Originally Posted by jimbo1710
Will being off by about 1/16 inch be okay with wdh? No trailer i'm at 37 inchs, trailer hooked up i'm at 37.5 inchs, With whd hooked up i'm at 36 15/16 inchs. I'm as low as I can go on the trailer frame mounts, and have to take out washer shims to change anything. The fastaway e2 hitch says minimum of 5 washers, but I only have 4 in now. Putting 5 in gets me about a half inch off to 36.5 inchs. Just wondering if 1/16 inch off this way will hurt anything. thanks all.
I also forgot to mention that you have the same hitch I do. The instructions tell you to measure the front fender before you hitch. Then hitch the trailer on without the weight distribution arms and measure your front fender again. Next, put on the weight distribution arms and measure a third time. When the weight distribution is connected, your front fender measurement needs to come back within 50% of what it was.
So, if yours is 37 to start, then with trailer it goes to 37 1/2, your goal with weight distribution is to get it back between 37 and 37 1/4. You went a little past by 1/16, which I still would call it good at 37. What's a 1/16th of an inch? A miss measurement?
Like others said. Take 'er out, see how it tows. If you have never towed before, you will feel the weight. You can also feel it "influence" the truck a little as in I can feel mine in the seat of my pants when I drive. It is a lot of weight back there. You shouldn't feel the tail wagging the dog.
Michael and Pamela
Colorado Springs, CO
2017 Roo 233s
Towed by 2016 Ford F-150 screw, ecoboost, maxtow
Replaced 2011 Ford F-150 screw, ecoboost, maxtow
that overheated every time it towed up hill.
10-03-2019, 08:18 PM
#27
Will being off by about 1/16 inch be okay with wdh?.
You sir win the troll of the month contest. I salute you!!
2016 Rockwood Windjammer 3001W
2016 F150 SCREW 3.5 EB
ProPride 3P 1400
