Used them more for the light.
Useful for light and moving air in the bunks.
If you don't know about condensation yet on the tent ends, I will attempt to explain. Since the vinyl covering you has zero insulation value, on a cooler, say 55, or 50 degree or less night your exhaled breath containing water vapor will rise and most likely condense on the top vinyl of the tent end. I often get "rained" on when turning over in the bed. This only gets worse when you "button-up" the trailer on a cold evening, as the moisture has no way to escape.
I usually open the top vent(s) in the trailer and start up the bunk end fan to move the air around and keep it from condensing on the tent over my head. Also serves as a source of white-noise to help you sleep! Some may ask how to keep warm? My electric cube heater does a fine job of heating the interior and the electric-heated bunk mattresses keep me cozy warm even in cold weather.
