Old 11-15-2017, 05:22 PM   #1
fedrocker's Avatar
Winterizing gone wrong - pump issue?
I’ve winterized before using the pump adapter, pulling the antifreeze straight from the bottle. Everything set up, diverted away from water heater. Turned on pump and it started to pump the antifreeze, but it never ended! Went through 3 bottles and nothing is coming from the faucets. I️ am attaching a picture - did I️ bypass to many valves near the heater?Click image for larger version
There is some leaking of antifreeze outside the RV under the pump location - not inside the RV?! Argh.
fedrocker is offline   Reply With Quote
Old 11-15-2017, 05:42 PM   #2
I don't winterize with antifreeze so I can't give you expert advice, but it looks like you have all your valves shut and I don't believe that to be correct...but again I'm not 100% sure. If you've gone through that much antifreeze do you think it could have been pulled into your freshwater tank?
m
2014 Flagstaff Shamrock 21SS
2018 F-350 Crewcab Lariat 4x4 6.7 powerstroke
Deputy Fire Chief-09-11-2026 retirement!!!
hybridlife is offline   Reply With Quote
Old 11-15-2017, 05:43 PM   #3
fedrocker's Avatar
m
Probably, if I️ shut off too many valves! Wonder where it all is right now.
Old 11-15-2017, 05:45 PM   #4
Mr. Dan's Avatar
You didn't loosen/remove the little strainer off your pump before you started all this, did you?
Old 11-15-2017, 05:46 PM   #5
fedrocker's Avatar
I️ used the bypass kit.
Old 11-15-2017, 05:48 PM   #6
Mr. Dan's Avatar
OK, my factory installed antifreeze sucker causes the pink stuff to go through my pump strainer. I couldn't see your bypass kit.
Old 11-15-2017, 06:16 PM   #7
Just as confused as you
Scrapper's Avatar
I’ve winterized before using the pump adapter, pulling the antifreeze straight from the bottle. Everything set up, diverted away from water heater. Turned on pump and it started to pump the antifreeze, but it never ended! Went through 3 bottles and nothing is coming from the faucets. I️ am attaching a picture - did I️ bypass to many valves near the heater?Attachment 156482
The valve in the middle needs to be lined up with the blue/red water lines. The top and bottom valves are correct for winterizing. They shut off the flow to and from the water heater.
Richard & Jill
Old 11-15-2017, 06:19 PM   #8
stevens233s's Avatar
This is how mine is when pumping antifreeze through the system DrainClick image for larger version
stevens233s is offline   Reply With Quote
Old 11-15-2017, 06:21 PM   #9
Turned on pump and it sucked it outta the jugs and out all exits!!!
Old 11-15-2017, 06:25 PM   #10
Who Dares, Wins
doc73's Avatar
Is the low point drains open.
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 11-15-2017, 06:26 PM   #11
fedrocker's Avatar
It would make sense - with that middle valve shut, I️ think that the antifreeze I️ pumped shot out the city connection, in other words backed up the pipes, so that would explain the antifreeze outside the RV on the ground.
Old 11-15-2017, 06:28 PM   #12
Who Dares, Wins
doc73's Avatar
It should not come out yhe city connection. Has a check valve. It could be stuck?
2015 Chevy HD D-Max
Old 11-15-2017, 06:30 PM   #13
fedrocker's Avatar
It’s all in the ground! Haha - I️ know that the inside of the RV is dry, so it leaked out of the RV somehow.
Old 11-15-2017, 07:00 PM   #14
Is there AF in the WH? Youroo!!
Old 11-15-2017, 07:01 PM   #15
fedrocker's Avatar
No, bypassed.
Old 11-15-2017, 07:08 PM   #16
No, bypassed.
Sure? Is the Drain Plug Out? Valves have been know to Fail! Youroo!!
Old 11-15-2017, 07:21 PM   #17
KMP44's Avatar
^^this^^
2022 Columbus 379MBC (Previous 2013 Rockwood Roo 23 IKSS)
2023 F-350 (Previous 2017 F250, 2005 F-150)
KMP44 is offline   Reply With Quote
Old 11-15-2017, 07:35 PM   #18
Who Dares, Wins
doc73's Avatar
I do not know if this was asked... If you are sure it is just "coming out" why are you winterizing? Did it already get a freeze or are you ahead of it? The reason I ask is did it already freeze and break something.. I have been there with the water filter housing once and an outside shower twice. There is just only so many places water should be coming out of a RV...
2015 Chevy HD D-Max
Old 11-15-2017, 07:35 PM   #19
fedrocker's Avatar
Originally Posted by KMP44 View Post
^^this^^
No, the caps on the drain pipes are on - because I️ planned to fill up the pipes with antifreeze...
Old 11-15-2017, 07:35 PM   #20
fedrocker's Avatar
Yes, I️ took out the anode rod. No antifreeze there
pump, winter
