Old 08-27-2019, 08:47 AM   #81
We need to figure out how to have a R/V electrical 101 class.
This thread has a LOT of misinformation in it.
Days Camped: '17=30 '18=51 '19=58 '20=98
Old 08-27-2019, 09:15 AM   #82
X 10!!!
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 08-27-2019, 09:19 AM   #83
Old 08-27-2019, 09:26 AM   #84
...far N Georgia!
formerFR's Avatar
true, and there are actually quite a few videos online(youtube especially) where any RVr can get a quick education in RV electrical...
the issue, though, is that most folks don't readily think of just going to look at a video for something they themselves don't know that they need to 'know'... otherwise, they just listen to what many of the others chime in with on these forums.
All of us are well meaning, and yes, some are more experienced in many things to do with the average RV, especially electrical, and sometimes that leads to comments that are not intentional 'wrong', but that maybe aren't worded properly so that those reading it can understand fully what is being 'said', or 'meant to be said'.
Sure, there are misconceptions about the difference between RV 30amp and RV50amp electrical service, as most folks who own a 30amp rv have no real need to know since they don't actually 'use' a 50amp outlet. It sure is simple to think that because the terminology between the two is so similar that it is only 20amps difference, and that's why the long discussions to 'explain' why it's not.
Regardless of whether some of us need initial education on basic electrical, or whether some of us like to 'tinker' with 'all things electrical', which makes us feel special, these forums give everyone a great starting point to ask the question, get some answers, and even get a little 'heated' by some of the responses when they don't line up with our own views, or understanding. Some do this because we're fearful that others will suddenly go out and electrocute themselves, or plug in and fry the RV, etc., but the reality is that some of those 'fears' rarely, if ever, happen...but the fear still drives it.
formerFR is offline   Reply With Quote
Old 08-27-2019, 12:52 PM   #85
Next time you go to an outing ask around to see if anyone knows about electrical modifications. Itís not rocket science. I did my 30 amp 80 ft run underground in conduit for less than $75. It will really be worth it!
brewnut44 is offline   Reply With Quote
Old 08-27-2019, 12:59 PM   #86
Villagerjjm's Avatar
To all the respondents who said they did the wiring themselves: I have not seen any indication of the inclusion of one key component that is is required by code. Can you tell me what it is?
Villagerjjm is offline   Reply With Quote
Old 08-27-2019, 01:10 PM   #87
rlh1957's Avatar
Originally Posted by tboots View Post
A 120v 30Amp RV plug will not go into a 240v 30Amp outlet. Just sayin...
I hear ya there... but somehow it has been done. I guess they had a hammer on their tool belt!
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
Old 08-27-2019, 01:14 PM   #88
rlh1957's Avatar
Most of us that do our own work have never pulled a permit, had an inspection or sign off on the work done. Most are licensed from the school of hard knocks and on the job must learn class. Usually until something burns down or sales inspection spots wires hanging or wrong wiring in a obvious code violation we go on.
24WS
FX4 Off Road (4X4)
Old 08-27-2019, 04:05 PM   #89
markjamestx's Avatar
We wired our RV outlet sub-panel box on the side of the garage about a year ago. A piece of advice, if you are going to wire it do the 50 Amp because you may want to upgrade to a bigger trailer in the future. Use an 50-30 adapter until you buy that new camper.
markjamestx is offline   Reply With Quote
Old 08-27-2019, 04:32 PM   #90
If installing a sub panel why not just install both 50 and 30 amp receptacles. Even if one upgrades RV later you'll still have a 30 amp outlet for a guest.
I hate adapters.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 08-27-2019, 04:42 PM   #91
Chuck_S's Avatar
I have a 30a Marine/RV outlet on the side of my house next to the driveway that allows me to use the trailer's shorepower cord easily. Wired via a separate 30a breaker. Since this only gets used a couple of times a year I fabricated a 20a outlet box for yard tools, air compressor, etc that's nearly always plugged in.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 08-27-2019, 04:55 PM   #92
-- Chuck
I am sure you are not having problems, but to me, that can't possibly be to code.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 08-27-2019, 05:04 PM   #93
I hate adapters.
Since I have a 30A trailer, I just swapped out the 50A RV outlet for a 50A welder outlet for my MIG welder, TIG welder and plasma cutter. My box has 50A, 30A and 20A. I could actually put the RV 50A outlet in there as well...plenty of room.
babock is offline   Reply With Quote
Old 08-27-2019, 05:41 PM   #94
Chuck_S's Avatar
The grey box is an extension cord. Very short.
-- Chuck
Old 08-27-2019, 05:47 PM   #95
Give $295 to the county?
2006 FR Salem 32SRV-LE 5th Wheel Toy-Hauler
2006 F250 Superduty 6.0 Lariat 4x4 Off Road
Slow Moon is offline   Reply With Quote
Old 08-27-2019, 06:01 PM   #96
...far N Georgia!
formerFR's Avatar
...why not just install both 50 and 30 amp receptacles...
I hate adapters.
well, if you think about it, the outlet itself is an adapter ... sorry : )
The Turners...
'14 Thor Palazzo 33.3 compact diesel 100k+miles since '14... US, Alaska, Canada...
AND a '14 Gulfstream Amerlite
AND a '07 ForestRIver Rockwood : )
Old 08-27-2019, 06:25 PM   #97
I Have mine hook-up to 20 amp GFCI and run everything I need including the AC without any problems. Of course Iím not living in it, but I do keep it heated to 50 degrees over the winter.
dpb.tech is offline   Reply With Quote
Old 08-27-2019, 06:54 PM   #98
I installed a 50/30/20 Ampere pedestal, roughly 150' from the feed, 100' of which underground. PITA to dig 100' by hand, but worth it. Also installed a water feed at the same time.
johnbryanpeters is offline   Reply With Quote
Old 08-27-2019, 07:18 PM   #99
Freetyme's Avatar
Pretty simple dyi. I had 100 A service to the garage already. Camper parked along side. Box , breaker, and 35' of 10 G wire $68. Main reason was to be able to run everything as if at a CG.
Freetyme is offline   Reply With Quote
Old 08-27-2019, 07:19 PM   #100
When I installed mine my neighbor had rented a "ditch witch" to install lawn sprinklers. He let me use it while he was going to get more pipe.
2004 Nissan Titan
