07-02-2016, 02:37 PM
#221
I go RV'ing not Camping
Originally Posted by LinemanSeth
When we hooked to power we turn the inverter off. The inverter is only on when not plugged into power. It converts the truck power to 120v or the camper battery if dry camping to 120v.
I don't think your truck would provide enough juice to replace what the inverter is using from your house batteries.
I find no matter what when I plug in my trailer the converter is drawing high amps until the house battery levels off.
Could be the issue
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
07-03-2016, 06:06 AM
#222
Has anyone added an extension/platform on the aft end of the trailer for a golf cart or atv? I have a golf cart I'd love to take camping. I saw a Flagstaff model with such a platform, not sure if it's factory or home-made.
07-03-2016, 11:57 AM
#223
Black tank acting clogged. Any suggestions?
07-03-2016, 06:06 PM
#224
Fixed up. Dang 4 yr old loves the tp.
07-07-2016, 07:16 AM
#225
Anyone know where the vacuum break is for the black tank flush? My tank flush stopped working on our last two trips
07-14-2016, 07:12 AM
#226
I found the vacuum break. It is located behind the closet across from the bathroom. You have to pull the drawer out to access it.
07-14-2016, 10:23 PM
#227
I live in Atlanta Ga, and it's super hot. I went out to camper and it's a million degrees in there. Does anyone leave the vents on top open during the summer to let the heat out or is it ok. Was just worried about it getting to hot to were it started drying out the fabrics and interior stuff. I know rain is a factor but I figured if the nose was high it might not run in the vents. Just a thought, first TT for us.
2016 Ram 2500 Cummins
2017 Heritage Glen 312QBUD
07-14-2016, 10:27 PM
#228
I had MaxxAir covers installed on all vents so I leave at least one open unless it is freezing cold.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
07-15-2016, 12:45 AM
#229
x2 I installed a vent cover so that I could leave mine open a crack specially in the summer. Nothing worse that arriving at the campsite and the trailer is hotter than Hades.
07-15-2016, 06:54 AM
#230
X3 Maxx air open most of the summer.
07-15-2016, 01:28 PM
#231
Great thanks
07-17-2016, 01:06 PM
#232
Can anyone tell me what this is and why it just started pouring water all of a sudden?
07-17-2016, 01:53 PM
#233
Looks like the drain for your fresh water tank. Valve must be open.
07-17-2016, 02:12 PM
#234
If that is your breather tube for your fresh water tank, it may be 'self draining'..... Mine did that on our first few trips. a suction is created by water sloshing or over filling and flowing out and then the tank is able to sometimes drain 2/3s because of the suction/siphon effect. A Dealer (or you) may have to rework the tube to stop the siphon effect.
Brother Les
07-17-2016, 03:34 PM
#235
Petcock turned to the open position and draining fresh tank. The other two hoses are overflow/vent hoses.
07-17-2016, 04:44 PM
#236
Thanks for the replies. I have never filled the fresh tank and have left this valve open all the time (should I keep it closed?). We have been in torrential rain for 2 days and suddenly this valve began draining. Wasn't sure if it was coincidence or? The suction effect makes sense, I'm sure there was some water in the tank, but we're talking gallons of water draining. After this trip I have a long list of warranty repair items so I'll add thus and have it checked for good measure.
07-19-2016, 12:41 PM
#237
Here is something I have been thinking about in regards to the "bowing" of the outside kitchen doors some of us have been experiencing.
I have been leaving my outside fridge turned on with my drinks in it when I am not at the trailer with the door closed. There is no venting in my outside kitchen. I know some trailers have a duct vent into the bunkhouse.
I wonder if the heat from the fridge is what caused the door to bow???
Also do you think there are any issues with the fridge long term leaving it running with the trailer all closed up??
Please discuss,
07-19-2016, 12:56 PM
#238
I leave mine on year round and haven't noticed any bowing
07-19-2016, 01:35 PM
#239
Is your kitchen vented to the inside of your trailer?
07-19-2016, 01:43 PM
#240
That's a good point to consider. On my last trip I started turning my outside fridge off when I pack up.
