Old 08-18-2012, 11:54 AM   #1
scotturner's Avatar
broken slide out shear pin
I was camping last month and when I was packing up to come home one of my slides started coming in at an angle. I had to push it in from out side while my wife was inside pushing the retract button. I think one of my shear pins broke. My slides are hydraulic and I have a sealed under belly in my fifth wheel. Dose anyone have an easy way of getting at the slide shear pin. I am thinking of cutting a big enough hole to get access to the pin. Any help/input would be welcomed.
Thanks Scott
scotturner is offline   Reply With Quote
Old 08-18-2012, 10:12 PM   #2
If the slides are hydraulic, there will not be a shear pin, no need for one. Since you didn't post year, make, model of the camper, will be hard to help, or even tell what slides you have.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 08-18-2012, 11:06 PM   #3
scotturner's Avatar
Sorry it is a 2005 all american sport 38RLDS two slides in the main living area. Each slide has one hydraulic ram and the other tracking arm has teeth running under it would that be a gear drive on that side?
2006 CR Dodge RAM, EFI live from anarchy diesel, BD Tanny, BD inter cooler, Jake break
2005 All American sport toy hauler
