I see your in Idaho. I looked up the number and that was for a large 5th wheel. Is that your trailer?
What are you trying to do? Do you want something that will take of the chill on cold mornings? Or are you looking to actually heat in cold weather?
If the former then you already have a 1500 watt firplace it looks like. Get another 1500 watt space heater and that should do the trick.
If the latter I don't see how you can truly heat your trailer with electric. Rough calculation. The furnace in your trailer is at least 35,000 BTUs which translates to ~11,000W of electric heat. 11K watts would need about 90 amps to run which your trailer is not going to do. Say hard wiring two, 2000W heaters would use only 34 amps and might work.
Jim M.
2020 Flagstaff Super Lite 26RBWS
Former: 2017 Rockwood MiniLite 2104S
2015 Silverado 2500HD 6.0L Gas
