I have a 2016 2306. The hot water just isn't hot enough. Is there a adjustment or mixing valve anywhere? I can't find a dern thing and the DW is not happy.
Posted in a rush. Went grubbing in behind to see if a mixing valve or adjustment existed... Well, the bypass valve was open. The hot probably acted as a venturi sucking cold water in and dropping the temp way down.
