Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 07-01-2017, 05:47 PM   #1
tman53's Avatar
How does one use Dometic A/C in fan only
On nice days I would like to be able to use my Dometic A/C unit to just circulate air in the TT. I've attached a photo of the thermostat I have in the TT.
Unfortunately I can't seem to have the fan run without the A/C running. Does anyone know how to do this? The manual I have is basically useless when it comes to this info.
Thanks in advance for any help!!
tman53 is offline   Reply With Quote
Old 07-01-2017, 06:22 PM   #2
tuckerdog1's Avatar
Don't have that thermostat, but shouldn't it be one of the "MODES" you'd cycle through with that MODE button?
Tuckerdog1
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB
2016 Windjammer 3029W Platinum
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
If you don't punish your children, life will.
tuckerdog1 is offline   Reply With Quote
Old 07-01-2017, 06:45 PM   #3
My Dometic thermostat is a bit different but if it is set to low or high it runs continuously, but on auto it cycles off and on with the compressor.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is online now   Reply With Quote
Old 07-01-2017, 06:48 PM   #4
Mr. Dan's Avatar
What settings do you see when you cycle through the modes (press the Mode button repeatedly)?
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115; Booked for 2022 = 41
Old 07-01-2017, 08:13 PM   #5
I believe there should be 4 modes on that tstat. Off (blank), fan only, a/c (snowflake) and furnace (flame). Cycle the mode button to the setting that only shows fan speeds. Select either low or high, not auto.
Remember though when changing back to a/c to select the fan setting you want, on low or high fan settings the fan will run continiously and will not shut off, auto will shut off and turn on as needed. I can't remember if it runs the same on furnace...I only used mine once and the furnace fan is seperate.
A/c mode
Heat/furnace mode
Off
Fan only mode in auto
Fan only mode, fan setting on low (you are wanting to select either this setting or the next for what you are wanting to achieve). To toggle through auto, low, high use the up/down buttons on the right when in fan only mode.
Fan only mode, fan setting high.
Hope that helps. I apologize for the picture quality, I just went out and snapped some quick pictures.
ProCharger is offline   Reply With Quote
Old 07-02-2017, 01:51 PM   #6
Dahagen
ProCharger...I like your thermostat. It looks like it has a light so it can be seen at night. Standard equipment, or is it something you added?
dahagen is offline   Reply With Quote
Old 07-02-2017, 04:16 PM   #7
Standard but it only backlights when you press it, otherwise looks like the original posters tstat when sitting idle.....and good thing it does because at night it is BRIGHT!!!
Old 07-03-2017, 07:11 AM   #8
Wolverine 1945's Avatar
Very nice Thermostat !!!
I just might think about changing to one of those !!!
Wolverine 1945 is offline   Reply With Quote
Old 07-03-2017, 07:31 AM   #9
Mr. Dan's Avatar
tman53, how about reporting back and telling us if this solved your problems - especially considering all the energy ProCharger exerted making and posting pics.
Old 07-03-2017, 07:59 AM   #10
RIGHT ON,,, Mr. Dan !!!
Old 07-04-2017, 05:47 PM   #11
tman53's Avatar
Ok guys sorry it has taken me soooo long to reply bit ove been out camping without phone or internet access.
Yes the info provided did help me. The t-stat is original equipment and it only lights up when touched for adjustment or to see the temp in the TT.
Thanks to all for the replies have a grwat holoday
Old 07-04-2017, 06:10 PM   #12
crunchman12001's Avatar
They are nice. I have 2 of them as OEM on my new rig. They are available in white or black. Check with Dometic to see if it is compatible with your ceiling unit?
Here is a link to purchase.
Dometic Single Zone LCD Control Thermostat 3313192.000 - $27.98
2015 F-250 FX4
Old 07-05-2017, 08:05 AM   #13
Thank You crunchman I will check it out !!!
dometic, fan
