05-26-2017, 10:53 AM
Mysterious blue lines with no shutoff
Cardinal 2o17 3456rl. Noticed water coming from this line while flushing black tank. Anyone know what they are
If not camping, I am Sailing
05-26-2017, 11:29 AM
If that water is coming from your black tank cleanout plumbing you have a serious plumbing issue. The factory installed cleanout is a closed self contained system.
05-26-2017, 11:32 AM
Flush works fine. I do have very high pressure though on my supply line to the flush connection.
05-26-2017, 11:36 AM
Regardless of the pressure, the black tank flush is more or less a closed circuit with the only outlet being the roof vent, inlet, toilet and the sewer hose connection.
05-26-2017, 12:15 PM
Getting back-to the original question does anyone know what those 2 blue lines are
05-26-2017, 12:19 PM
That's what we're trying to address, by telling you it should not be connected in any way to your black tank flush. It will be up to you to trace the lines and may require you to look inside the belly covering.
05-26-2017, 12:24 PM
Well we determine that 3 of us don't know what they're for
05-26-2017, 12:29 PM
And only one has seen them up close and personal.
05-26-2017, 12:37 PM
Out of Order
On my trailer, the blue lines are the low point drain for the fresh water tank. The only difference being mine has an on/off spigot attached to the end and yours simply shows an open tube. The color of the line would indicate a fresh water drain.
Todt and Connie and Hank the Doodle
2016 Wildcat Maxx 24RG
2016 Ford F250 6.7L Diesel
05-26-2017, 12:39 PM
That would be my first guess too. They have to be fresh water tank oveflow/vent lines.
2016 FR XLR Thunderbolt 395AMP
2015 Ford F350 CC SB 4x4
05-26-2017, 12:40 PM
Agree, but if the system is completely dry and you hook up the black tank flush you should NOT get water out of either low point drains even with the caps off or valves open.
05-26-2017, 12:48 PM
The valve could be located up higher.
I see one line with a valve further back.
That would most likely be the fresh drain.
2017 Dynamax Isata 4
I have a blue line with the valve on it about a foot to the left of it which is my freshwater tank
05-26-2017, 12:57 PM
I am wondering if your black tank flush and fresh water fill are either mislabeled or plumbed incorrectly. As others have stated, when using the black tank flush no water should be coming out of the plumbing other than the sewer.
It sure looks to me like it’s the fresh water tank overflow line.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
05-26-2017, 01:17 PM
could be the fresh water fill and the black water flush lines are reversed or miss labeled.
Dick & Betty
2016 Chevy Silverado 1500 crew cab
2017 Grey Wolf 23mk
05-26-2017, 01:20 PM
did the water start and stop with the black tank flushing? Or did you just happen to notice it while you were flushing?
what is above those lines in the trailer?
EDIT:
is this a brand new trailer with clean tanks? If so remove the sewer cap and open the black tank dump valve and try flushing. if nothing comes out try the other hose fitting.
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
05-26-2017, 01:31 PM
Scoundrel
Others here might disagree with me, but I would consider dropping half a teaspoon of mild dish soap in the black tank and run the flush cycle. If soap bubbles come out of those blue lines you definitely have some issues to resolve.
05-26-2017, 02:15 PM
Lines are not reversed. Black tank valve open water starts and stops when I turn incoming hose on and off. Fresh water tank was only 1/3 full when I was flushing, so probably not that overflow. I have flushed 3 times before.
I will have to remove bottom to see what is above.
05-26-2017, 04:58 PM
I have the Nautilus P1 water management sytem. It only drips out that pipe when I am flushing black tank and all the controls are set to Dry Camping
05-27-2017, 10:16 AM
just guessing. it looks like the trailer is leaning to one side (one set of wheels on asphalt, the other on grass). if fresh water tank was full it could be the lean is causing water to exist the overflow. could the other one be a drain from the refrigerator? there no way I can conceive of a drain like that to be associated with either the black or gray tanks. send that picture to the cardinal support person at forest river and ask them.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
