09-17-2017, 08:47 AM
Sap on tinted windows.
I tried several solutions
but can't it off. Can a razor blade be used without damaging window. Glue is dry and tough to get off.
09-17-2017, 08:50 AM
Assuming this is on exterior glass.... use lighter fluid on a microfiber. That will resolve quickly.
Note lighter fluid is great for lots of things.
09-17-2017, 11:13 AM
Plain hand sanitizer works great too.
09-17-2017, 11:43 AM
I have used Goof Off on my truck to get dried sugar pine sap off. with good results.
Retired Navy
2016 Flagstaff 26 FKWS
09-17-2017, 12:53 PM
Hand sanitizer works awsome!
09-17-2017, 02:26 PM
Next time try clear water with a clean towel. Other products harden the sap and make it tougher to remove. Trick I've used for years. It may still work . Try it.
09-17-2017, 04:39 PM
turpentine is a good solvent for tree sap. It is actually made from Pine sap.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
09-17-2017, 04:45 PM
Haven't had anything yet that Dawn dish soap wouldn't take off.
Mark B.
2021 GMC 1500
Anderson WDH
09-17-2017, 05:12 PM
Sappy Windows
As one person said, "Goof Off" will probably remove it. But the most simple solution is to use regulas cooking oil, followed by soap.
09-17-2017, 07:08 PM
x 2 on the hand sanitizer
09-17-2017, 09:02 PM
Another thing you might try is rubber cement thinner. It is fairly pricey, but, a little goes a long way. We used to use it back in the days of photographic cells for slide presentations. But, if you have some white gas (like Coleman camping fuel), it is made from basically the same stuff - naphtha and you can buy it by the gallon at most sporting goods stores. I have not had it take the plastic off of anything (or melt it like acetone does) and it works great for most glues. Just another thing to try.
09-17-2017, 10:48 PM
The best solution to clean auto windows is a mixture of 8 oz. Denatured Alcohol, 8 oz. & 1 table spoon white vinegar, with newspaper. No streaks and removes sap.
09-17-2017, 11:43 PM
I 2nd dawn dish soap.
09-18-2017, 08:45 AM
I am surprised but I have used Hand Sanitizer to remove pine tar from my hands !!!
09-18-2017, 09:17 AM
it must be the alcohol in the hand sanitizer that is removing the sap. Going to give that a try next time I get sap on the truck or trailer
Retired Navy
09-18-2017, 08:52 PM
SAP ??? Too many abbreviations ...
When I started reading this post I was puzzled what SAP was an abbreviation for. Then AHAH! Too simple, tried to make it more complicated. LOL
David Cournoyer
2015 F250 SRW 4x4 Crew Cab Platinum
6.7L Powerstroke V-8 Diesel
2013 Rockwood Windjammer 3001w Diamond
09-19-2017, 06:48 AM
Scotsman
Skin So Soft
If you can find it, I use a product called skin so soft. Whatever is in it, it is gentle, cheap and it works. Comes in a little spray bottle. My DW told me that it's an Avon product. Also keeps the bugs off you. Good luck.
