If you have hydralic operated slides. Forest River uses a lot of Lippert products on their Hydralic products. Some Forest River units combine their slide operations into one switch to save costs. You can tell by looking at the pump and see if there are three brass valves. You can control each slide be closing the other two valves. If no valves are visabe, then they cannot operate seperately. When the pump is on, the slides come out seperately with the smaller one first. On some units, each slide has its own switch inside the coach, then you can control each slides operation.
Ken and Velda
Dahlgren, VA.
2008 Georgetown XL 378
2010 Ford Escape Limited
