01-11-2018, 10:20 AM
Storage
While storing the camper, should I leave it plugged in and if yes, should I turn off the inverter? Thanks for your help!
01-11-2018, 10:24 AM
I store mine in my driveway year round when not in use, and I ALWAYS leave it plugged in. I use the refrigerator all the time........and the icemaker.
My inverter......doesn't matter if you leave it on or off. It will kick on if needed and kick off if not. Many leave theirs own in case of loss of shore power. I don't, I turn mine off manually when on shore power. I couldn't actually tell you why. But my refrigerator will stay cold just fine for a day or two if door not opened, even without power.
FROG AR-0019-242
01-11-2018, 10:39 AM
Great. Thanks, this is our first camper. I wasn't sure if running the inverter for a couple months would hurt it or if having the inverter off would be bad on the batteries. Thanks again
01-11-2018, 10:43 AM
Remember...
CONverter creates 12v from 120v and charges battery.(ies)
INverter creates 120v from the 12v (battery(ies)
01-11-2018, 10:53 AM
Originally Posted by 5picker
Remember...
Thanks, so if it is manually powered off, what does that do to the charging of the batteries. If manually switched will the batteries just keep getting charged and not shut off when fully charged like a trickle charger would do.
01-11-2018, 10:59 AM
The CONVERTER charges the batteries, not the INVERTER. I leave my unit plugged in to shore power for the refrigerator, but it also keeps the battery charged because that also engages the CONVERTER (the battery charger). I turn off the INVERTER when on shore power (But don't have to).
Hope that helps. It confused me too for a long time.
FROG AR-0019-242
01-11-2018, 11:10 AM
Nothing. The INverter does NOT charge the battery(ies) the CONverter does this. (separate item)
No, see above.
The CONverter is a multi stage charger and will go into 'trickle charge' when necessary, even when shore power is connected 24/7.
Now the caveat... there are some INverters that ALSO charge batteries but this set-up is uncommon and not usually installed this way from the factory. I only say that to rule out those instances where it can be done differently.
In reality, we have NO CLUE how your unit is wired. We are only referencing typical installations with our advice.
01-11-2018, 11:15 AM
No, see above.
Thanks again! Appreciate it
01-11-2018, 11:27 AM
No problem.
Couple suggestions...
First, WELCOME!
I see you have just a few posts.
There are a LOT of good contributors here.
Second, fill out a signature line so your unit is referenced within each post.
Those using the web site can then see your signature and what kind of rig you have. It often helps us help you.
Third, when asking for advice, always try to post as much information as possible (including make/model numbers) of the appliance/system you are asking about. Those looking at your posts using a mobile app can't see the signature line so posting as much info as possible (within the post) helps us when we are using the mobile app to visit this forum.
01-11-2018, 11:29 AM
Will do. Thanks! Bring on summer!
I left my last trailer plugged in for close to 22 years, only disconnected when on the road. Went through two sets of batteries the entire time.
Check water in batteries regularly and use only distilled water to fill to the proper level. A lot of electrical devices prefer being left on continuously rather than being subjected to the surge of current when plugged in cold.
Converters draw very little current when not charging batteries or powering lights so you really don't save money by turning off.
Just watch the battery water levels, checking monthly to start and after learning how much water they use, adjust schedule accordingly.
01-11-2018, 04:25 PM
Curtiss, it would also help if you listed year, make and model you have, in your profile.
As was said, you're mixing up INverters with CONverters.
But if we knew what RV you own, we might know if it also has an inverter.
All RVs have converters but few have inverters.
