02-08-2021, 03:49 PM
nmdcporter
Tail Light failure
Hello,
I have a question. I have a 2018 Flagstaff travel trailer 27RLWS. My left LED tail light is acting up. The turn signal, Brake and running light are working but very dim. I thought it was going to be the ground wire but I took connector off and replaced it with no success. I check the voltage and getting 13.6 V no issues. My right rear tail light and all other lights are fine on the rig. I'm thinking I need to replace the tail light. Does anyone no where I can get one or a part number. I've called and looked but came up empty. Thanks
NMdcporter
02-08-2021, 04:17 PM
Have you tried replacing the bulb?
02-08-2021, 04:52 PM
Kanadian Kamper
OP reported it’s an LED unit. There isn’t any bulbs.
Ken and Terry
02-08-2021, 04:55 PM
Kanadian Kamper
Originally Posted by nmdcporter
Hello,
NMdcporter
Can you physically move the working light unit to the trouble side to see if your theory works?
Here’s some contact information for part numbers you may be looking for.
https://forestriverinc.com/rvs/conta...gstaff-classic
Ken and Terry
02-08-2021, 06:14 PM
My bad.
02-08-2021, 06:16 PM
nmdcporter
As someone said LED unit completely sealed.
02-08-2021, 10:36 PM
Boss Ox & Drovergirl
Can you remove the tail light assembly without too much hassle and connect to a separate 12v power source to determine if it's the light or the wiring?
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2016 GMC 3500HD Duramax dually
1992 Goldwing Aspencade
02-09-2021, 07:55 AM
nmdcporter
Might be able try this after I move by making some jumper wires and connect to truck. Current location it isn't doable due to back in site. But I'm getting 13.6 vdc at the tail light so I couldmake a ground wire and try.
02-09-2021, 07:59 AM
nmdcporter
Removing is easy but wires are crimped in connectors, being on the road without the correct tools makes it a little difficult.
02-09-2021, 08:04 AM
nmdcporter
Removing is easy but wires are connected using crimped wire nuts, being on the road without the correct tools makes it a little difficult to complete.
02-09-2021, 08:44 AM
Connect (+) side of volt meter to the ground side of the light module as close to the actual module as possible. Connect the (-) side of the voltmeter to a GOOD gnd and measure the voltage. If the value is not very close to zero, you have a bad ground connection.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
02-09-2021, 08:55 AM
I have the same failure on the passenger side. License plate light, turn, and stop all work. tail light does not.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
02-09-2021, 09:04 AM
I have LED bulbs in a conventional light housing -- they're replaceable. And common.
The license plate light is usually just bleed out from the tail light, not a separate bulb or LED, so if the tail lights work the license plate light should too. Same electrical circuit and wire. Turn signals and brake lights are separate normally the same circuit. Note the signal interrupts the brake light.
In the case of a sealed LED housing the only convenient way is to replace the entire unit. Units with bulbs or LEDs replacing bulbs are easy. When that's done note LEDs are polarity sensitive. Bulb in backwards won't light.
-- Chuck
02-09-2021, 03:59 PM
Commercial Member
Hello,
NMdcporter
nmdcporter,
We would be happy to provide assistance with your Flagstaff's tail light. Please contact Rayna Dimitroff in our Customer service department through the following personalized and direct link: https://www.forestriverinc.com/Direc...84830892746887.
This direct link is provided for your convenience in order that we may resolve your concerns as quickly as possible. We will strive to respond to you within 24 hours of receiving your correspondence.
Respectfully,
Forest River
02-10-2021, 03:47 PM
nmdcporter
Originally Posted by ES_FR
nmdcporter,
Respectfully,
Forest River
Thanks for the offer, it was the LED tail light. Replaced and all good.
02-10-2021, 03:51 PM
nmdcporter
Thanks for the suggestion everyone, it was the LED tail light. Found one at Action RV in Rockport, TX, I replaced and all good. Back on the road.
Nmdcporter
02-10-2021, 03:58 PM
nmdcporter
I replaced the whole tail light and all is good. I would first check ground connection.
NMdcporter
02-18-2021, 09:43 PM
Hello,
NMdcporter
I suspect a bad ground. Even though you replaced the connector on the lamp assembly, the wire itself may not be bonded. You can test by temporarily running a jumper from the ground wire on the lamp assembly to the frame of the trailer and then testing the lights. I had the same problem with an enclosed car trailer and ended up having to run some new grounds to the taillamp assemblies.
