Probably not necessary if the tire wear is not excessive on the opposite side. I have replaced single tires when I had a puncture repaired. Trailers do not have the same handling issues as powered vehicles. It does makes sense to use the same tire brand/size though.
As an fyi... you may get tons of opinions from folks on this forum. If you want tire information from a true expert with 40 years as a tire forensics engineer, check out Roger Marble's website: RVTiresafety.net There is a wealth of excellent info on his site.
__________________________________________
2014 Spartan 1032
2015 GMC 3500HD Denali 4WD/Duramax
