Vibrations from outside speaker inside the trailer
We have an issue with the outside speakers. When they are on there is a vibration coming inside the trailer. It appears to be coming from the cavity that is under the shelving above the sink. This cavity is about 2 inches and goes the length of the bottom of the cabinet. Has anyone else had this problem? If so how did you fix it? I'm thinking that I take plug out that is under the cabinet and put some foam in the slot that is accessible through this slot so as to stop the 2 panels from vibrating.
