03-01-2020, 05:17 PM
Which fifth wheel to double tow with?
I have a 1,600 pound boat that I tow to the lake two hours away from my house. Then, I drive two hours back to my house to retrieve my Jayco travel trailer. After a few camping trips & six hours driving to set up then six hours driving to get the boat & travel trailer home I have decided to purchase a fifth wheel, add 2" receiver to double tow with.
Tow vehicle is 2013 ram 2500 diesel
Wants:
Full profile so I can stand up next to the bed (I'm 6' tall)
North south bed for the night stands
No "dual access" bathrooms for privacy/scent concerns
Traditional rear living floorplan (Couch, dinette & theatre seating)
Less than 35' long
I walked through a Sierra half ton & while I like the bedroom & floorplan, I discovered my concerns with "dual access" bathroom. Also the unit appeared to have a 7" frame (too small for double towing???)
I walked through a Cherokee Arctic wolf & while I like the 10" frame, price & layout, I hit my head in the bedroom. Also there is only room for a 20"ish TV up in the corner in the bedroom.
I like the Salem/Wildwood Hemispheres & Heritage glens that I have walked through, but their 338Bar is an east west bed and is too long (38'6"). I also like the 290RL, however it has "dual access" to the bathroom.
I have looked at fifth wheels that come with rear receivers for double towing like the Jayco Eagle HT's & Grand Design reflections, however the ones short enough to double tow with are mid profile & have "dual access" to the bathrooms.
I don't want to spend more than $40k including taxes out the door.
So far units I like are:
Impression 28rss (8" frame)
https://forestriverinc.com/rvs/trave...ion/28RSS/3757
Wildcat 290rl (not sure on frame size)(not sold in my region)
https://forestriverinc.com/rvs/trave...cat/290RL/4288
Do you think an 8" frame is strong enough to tow my boat down the freeway?
What other brands should I look at that would fit my criteria?
Would rather buy used so I wouldn't to eat the depreciation & hopefully would have the bugs worked out.
fyi, located in the central coast Ca, most dealerships are several hour drives.
Thanks!
03-02-2020, 10:03 AM
I don't believe you can double tow in CA. I would verify that first unless you already have.
03-02-2020, 10:15 AM
KSH, it is legal as long as the first trailer is fifth wheel; neither trailer exceed 28'6"; each trailer has brakes & you have a CDL A with doubles endorsement
03-02-2020, 08:55 PM
Good to know! I've seen it only twice, both out of state plates.
03-03-2020, 01:48 PM
Am I reading this right?
So, you need to find a fifth wheel that is no longer than 28'6" to comply with CA double tow? Do they make them?
2023 Silverado 3500HD CC Long Bed Diesel DRW
2016 Silverback 33IK
03-03-2020, 02:07 PM
Not sure about Cal. as they have some weird laws, but elsewhere all that is needed is a recreational doubles endorsement on your drivers lic. not a cdl
03-03-2020, 02:14 PM
And of course most states east of the Mississippi don't permit double towing of anything but tractor trailers and that's definitely with a CDL and only on certain highways.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 30 Months on the Road Since 2008
03-03-2020, 02:46 PM
I double tow with a Puma 253FBS. It’s 27’3”. It’s kind of an entry model, but Pumas are pretty good quality and I got a great deal on it. Plus it’s very much 1/2 ton towable, for mine anyways.
2017 F150 XLT 3.5l Eco Boost, SC, 8' Box, 4X4
Max Tow (10 speed, 3:73, 11,700lbs), HD Payload (2440lbs)
2015 Puma 253 FBS
2013 Hyundai Santa Fe
2000 Honda EX 400, Rad Rover 6 Plus
03-03-2020, 03:35 PM
Double Tow
IMHO - None.
I think its just too dangerous.
I believe, not 100% sure, it's not legal in California. Check the states you're going through.
03-03-2020, 03:57 PM
You've done your homework on the legalities of towing doubles in CA. I did it for many years with a '95 Fleetwood Savanna 27-5J. The 5W was just over 28' and I pulled a 23' Cole that weighed over 3K for just the boat. Total length was just under 75' and the combined trailer weight was 14K. We shopped all over and found the Fleetwoods had the heaviest frames at the time. It was a 10" C-channel and I fabricated my own hitch.
As you're limited to 28'-6", my suggestion would be to find a 5W with the highest GVWR and a wide margin for cargo capacity which would indicate a heavier frame. That 8" frame may by fine but, if possible, check and compare the wall thicknesses.
BTW, having towed that combination for several thousand miles over many years in California, Arizona, Nevada, and Utah, I never once got pulled over.
03-03-2020, 04:25 PM
Just remember that laws are subject to change. I doubt that there would be any Grandfathering clause if they did.
03-03-2020, 04:56 PM
Many mid-western states allow towing "recreational doubles". Here in Michigan you need a CDL "T" or an "R" endorsement on your operators license. There are overall length restrictions and weight restrictions on the double.
John & Cheryl
2016 Ram 1500 Big Horn
2019 Palomino Solaire 202RB
"Why yes, this is my circus and these are my monkeys!"
03-03-2020, 07:06 PM
We pull a 30ft Rockwood 5r and a 19 ft boat. Pull them with a F350 diesel. Been a lot of places, no issues.
03-04-2020, 12:04 AM
To everyone that mentioned the CDL requirement in CA to tow doubles, you are right, and I currently have a class A license but have yet to add my doubles endorsement, however when/if I buy a fifth wheel for the purpose of double towing I will add that endorsement.
As far as length of the fifth wheel, my initial search were for fifth wheels with ideal layouts close to 29' as I figure CHP would have a hard time eye balling a double towing rig being 6" over length on the fifth wheel.
Ever since this idea of double towing crossed my mind, I have seen countless people double towing, many, if not all, over length with their fifth wheels. The majority of these people double towing with 40'+ toy haulers. I have spoken with quite a few of these people about their length, their response being "I've never been pulled over" & "I have CDL A + doubles/triples endorsement".
After speaking with several CHP/DOT bit inspectors, their response is "most CHP aren't aware of the 28'6" length restrictions".
This has led me to my current criteria in search of a fifth wheel less than 35' (Don't want to push my luck getting pulled over) with a strong enough frame to handle my lake boat (1,600 pounds)
I realize that I am asking for a car with four different rims, but I figured if anyone knew of a fifth wheel with the layout I am searching for & a stout frame, it would be this forum.
Thanks for the replies, I do appreciate them.
Mitchell
03-04-2020, 12:16 AM
The impression 28rss appears to have a GVWR just over 10k + pin weight with an 8" frame
The wildcat 290rl appears to have a GVWR of just over 11,500 + pin weight (not sure on frame size but appears to be re-skinned impression, 8" frame???)
I've noticed that heartland uses 8" frames our their Milestone fitfh wheels which have GVWRs of 15k (not sure on wall thickness)
Also, Jayco Eagle Ht's are rated to tow 3,500 pounds & I believe they use 8" frames, once again, not sure of their wall thickness. Same can be said about grand design reflections (may be wrong)....
Any input is appreciated
Mitchell
03-04-2020, 08:14 AM
You can IF the first trailer is a 5er.
If the first it a bumper pull, NO second trailer.
We have a 2012 Wildcat Sterling 32RL that we purchased used at a dealer. It has a 2" hitch receiver which I believe to have been factory installed, but it could have been installed by the previous owner.
I tow a boat that weighs about #1200 with no problems.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
03-04-2020, 12:49 PM
several of the wildcats came with the 2 inch recevier on them,
our had one
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
03-04-2020, 01:46 PM
Befuddled wanderer
Have you checked out the Rockwood UltraLights? I really have no idea if the frame is built in such a way that you could tow your boat behind, but I think you could find one that meets the rest of your requirements.
Perhaps this one? https://forestriverinc.com/rvs/trave...te/2441WS/4384
Oops.. guess all the Rockwoods have the pass-through bathroom... But it's a tall pass-through bathroom!
I purchased a 2891BH model last summer and I know the bed area is tall enough to allow a 6' person to stand. I'm 6'9" and can't stand straight up, but it's pretty close.
03-04-2020, 09:36 PM
cc102bob, I really like the rockwoods with the exception of the dual access to the bathrooms. I have also read some troubling things about their frames when it comes to double towing on similar forums however they were second hand accounts to begin with, but enough to scare me. Poster mentioned not to try and double tow with any unit that classifies itself as an ultralight which made sense to me.
Mitchell
03-04-2020, 09:53 PM
Befuddled wanderer
Mitchell
My unit (and I'm guessing most Rockwood units) has the whole underbelly covered so that you can't see the frame. I've not had a reason to remove it and inspect things, so I have no idea just how beefy it is. I do know that some of the light weight comes from extensive use of aluminum and generally lighter weight materials, but I suppose they could also be skimping a bit on the frame.
Edit: I should say you can't see anything inside the main rails... You can actually see the main rails, but I'm thinking the inner structure would also be important.
As for the dual entrance bathroom, you could always cover up the door that faces the bed and use that whole wall for a huge screen tv...
I've toyed with the idea of towing my fishing boat behind, but my wife and I decided it worked out better to just take two vehicles. That way we have my Pilot to drive around in while on vacation and my big ol' heavy duty gas guzzling truck can just sit. She has learned that she can pull the boat OK, but she still doesn't have any interest in trying to drive the truck and trailer. heheheheh.
Bob
