05-16-2018, 08:11 AM
Winterizing inlet purpose?
So got a quick question about the antifreeze inlet purpose. On my 2018 8295ws, when I winterized it last fall, it worked fine. However it also ended up putting the antifreeze into the water filter housing. I didn't have a filter in it but it got me wondering. If they are connected (and they are near the pump inlet) why have two? Couldn't you just bring the TV stuff through the regular city water connection? Or did the back flow happen because there was no filter in it?
Either way it worked fine and this spring I am happy to report no leaks. Next weekend is camping!!!!
Robb Feldhege
2009 Chevy Duramax 2500HD
2018 Signature UltraLite 8295WS
If your best was good enough today........
It won't be tomorrow.
05-16-2018, 08:22 AM
The city water connection will not lift to the pump. The filter housing is on the high pressure side. I put a filled water bottle in the filter housing to cut down on the amount of antifreeze that it takes.
2015 335DS
05-16-2018, 08:34 AM
the city water connection usually has a valve to control where the water goes. in normal mode the incoming water has water pressure from the faucet you connect to. this water pressure is used to push the water through your internal plumbing. your water pump is not used for this. and in the normal position the incoming water does not go into your fresh water tank. if you move the valve to the fill position the incoming water, again using the faucet water pressure, will be directed to fill the tank. once you have water in your fresh water tank you can use your pump to add pressure to have it flow throughout your internal plumbing. thus you can get water into your plumbing either by using the city water connection with the valve set to normal, or from the tank by using the pump. there is a winterizing valve that changes the suction input for the pump between the fresh water tank and the winterizing input hose. you do not want to put antifreeze into the fresh water tank. so change the winterizing valve to winterize and let the pump suck in the antifreeze using the winterizing input hose. now you could put in antifreeze through the city water connection if you have the valve in the city water position. but you would need an external pump to pressurize the antifreeze in order to push it through your plumbing. using the winterize valve setting and the winterize pick up hosed allows you to do this using your internal pump.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
05-16-2018, 10:31 AM
There is no back flow. The built in water filter is plumbed as a whole house filter and all fresh water, either from the pump (holding tank/antifreeze inlet etc.) or shore (city water) passes through the filter for distribution to faucets/toilet/water heater etc..
05-16-2018, 01:25 PM
But then how did the antifreeze end up in there? Does the antifreeze inlet come through there too?
Robb Feldhege
05-16-2018, 01:37 PM
The antifreeze was brought into the system by the water pump.
You should have a valve that selects either the fresh tank or the antifreeze (winterization) connection. Depending on the valve's position, the pump will draw from either the fresh tank or the antifreeze port.
05-16-2018, 03:21 PM
Correct, the antifreeze travels:
1) Inlet
2) antifreeze/FW tank selector
3) onboard filter housing
4) rest of plumbing
On our Flagstaff, I got a couple of PEX valves, a couple of PEX Ts and some tubing and built a bypass around it.
Edit: adding photo
05-16-2018, 06:22 PM
Where's the filter in this scenario?
05-16-2018, 07:13 PM
Mine is inside the passthrough compartment. Near the inlets on the outside.
Robb Feldhege
