Old 05-02-2021, 12:15 PM   #1
Smile Converter location
Does anyone know where the converter is located on a Cedar Creek Cottage? We have a 2019 40CRS. Owner’s manual is not specific to our model.
Thanks in advance.
Beckynoodle is offline   Reply With Quote
Old 05-02-2021, 12:21 PM   #2
NMWildcat's Avatar
They are usually in the area of the fuse/breaker panel (power panel). There are two types of converters, integrated with the power panel and completely separate.
So look behind the power panel and in adjacent compartments for the separate kind.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
Old 05-02-2021, 12:25 PM   #3
2018 Cottage CCK
See below link:
https://www.forestriverforums.com/fo...ml#post2534792
Full-timers since 1999
2018 Cedar Creek Cottage: August 2017
Located: Arizona
Cottage_Owner is offline   Reply With Quote
Old 05-02-2021, 12:56 PM   #4
U.S.ArmyVeteran's Avatar
They have a cooling fan that will run based on the temperature in the unit.
You can try to listen for it. Turn any noise makers off in the trailer and let it get warm inside. Ours is just loud enough to hear when running.
U.S.ArmyVeteran is offline   Reply With Quote
Old 05-02-2021, 04:24 PM   #5
Just as confused as you
Scrapper's Avatar
Or you can turn on all the lights, both inside and out, along with the stereo and vent fan. That will cause the converter to go into a higher charge mode and the fan will run faster causing more noise.
Richard & Jill
Old 05-05-2021, 10:58 AM   #6
We have a 2015 forest River vengeance Our lights went dim, then out. Maybe the converter? Does anyone know where it is and what it looks like?
Peggy and Dwayne R is offline   Reply With Quote
Old 05-05-2021, 11:10 AM   #7
NMWildcat's Avatar
Read the above thread and look at the link in #3. Even if someone has the exact same model RV as you, it doesn't mean everything is in the same place. Follow the advice above, do some looking behind panels, in cubbies, and I'm sure you will find it.
Old 05-05-2021, 11:25 AM   #8
Thank you. What will it look like?
Thanks Peggy
Old 05-05-2021, 11:37 AM   #9
NMWildcat's Avatar
Thanks Peggy
Tbere are several models. Go to this website for pictures. Also this is a great company to use to buy a new one or just get advice. Randy and his crew are top notch. https://www.bestconverter.com/
Old 05-05-2021, 11:39 AM   #10
Ok. Thanks for your help
cat, converter, location
